Mar 18, 2005 - 2:22 PM
Enthusiast ![]() ![]() Joined Jan 5, '05 From Upper Darby, PA(5 min away from Philly) Currently Offline Reputation: 3 (100%) |
I want everyones honest opinion on this. What do you all think about an Electric supercharger on a celica?
here is an example: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...bayphotohosting |
Mar 18, 2005 - 2:25 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) |
and let the flaming begin lmao
-DMC |
Mar 18, 2005 - 2:28 PM
It's been covered in the past, and a search will turn up more info, but basically, it's worthless.
Mar 18, 2005 - 2:32 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Seen this cr@p so many times on so many different forums. And it always gets the same response. I can't understand why on earth people fall for the marketing blurb and buy them (sorry Drew-877, no disrespect intended). They are the biggest waste of money ever and have no hope whatsoever of working. Money would be far better spent on alternative, proven products. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Mar 18, 2005 - 3:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
i'll totally agree with them. i personally think it's crap. if you are really considering ESC (electric supercharger), i'll recommend thomas knight ESC. they are more professional in stuff like this... but what i don't like about these is they act some how like a NOS? ya gotta hit on a switch to activate it and stuff... which that much electricity circulating, god knows what will happen lol..
Mar 18, 2005 - 3:18 PM
I think its a great idea...to poop on!
Mar 18, 2005 - 3:19 PM
Enthusiast ![]() ![]() ![]() Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
wow they want 100 bucks for a little fan thats all it is.
Mar 18, 2005 - 3:37 PM
I dont have one. I just see them on ebay and I was curious about them. I never seen anyone with one and I was wondering why. I was MAYBE considering getting one but before I did I wanted to get everyones opinion. SO dont be mean to me.
Mar 18, 2005 - 6:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) |
the ebay electirc superchargers are crap!! The amount of power that can be delivered by your battery or alternator without a larger transformer is no where near enough to spin a compressor to a resonalbe, sustainable speed to provide positive pressure.
Shin is right, that the only electric spercharger that is proven sort of acts like nitrous, as its a one shot deal. You press a button and it activates the supercharger. But this only lasts for a few seconds, as the power drain is enormous and thus can only be sustained for only so long. Its battery will recharge over time, but not soon enough to use it in the same run, or a run thats within the hour. -------------------- Its Orville's Celica, i just drive it... |
Mar 18, 2005 - 6:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
okay... so this centrifugal electric blower flows 1200 CFM of air (which is pretty damn impressive i might add)
on a 3sgte motor say you want to run a standard 13 PSI, you would need to be running 431 CFM with a 1.88 pressure ratio at 7200 RPMs... this means you need to be running 431 CFM @ 1.88X the atmospheric pressure. at 26 PSI you are still only at 634 CFM with a 2.77 Pressure ratio. so whats it all ammount to, well you really have no clue what this electrical unit is capable of. obviously its max 1200CFM is BEYOND overkill for any application we would be using it for, so when a fan wants to push more air and isnt allowed to, it has alot of restriction on it, which causes alot of current draw from your battery, and causes the fan to heat up and possably burn up. i can also almost guarantee you will feel alot of power surging because it's fan speed will be limited by nothing other than the resistance put on it by the air since there is no VFD controller on it (just an on/off toggle switch as described in the ebay posting), so it really depends what kind of static pressure the unit is capable of holding, alot of this "they dont do anything, they are just a fan" is true because they are not capable of holding that pressurized air like a turbo or true centerfugal supercharger is designed for, these electric units usually are not intended for use in high static pressure applications, usually they are just use for circulation where there is little restriction, not an application where when the throttlebody closes, the entire system is 100% blocked. id be interested to see what kind of pressure drop they are able to hold across the fan, but i still think for the other reasons mentioned they aren't quite capable of being used for this type of application yet. -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 18, 2005 - 7:35 PM
If they are so good, then why do you not need to change your ECU? I mean, a n/a car's ECU won't be able to sense boost - obviously just vacuum. Add forced induction and when you hit positive pressure, how is the ECU going to cope? No mapping etc for ignition, fuel etc. Engine would detonate like mad and not run properly at all. If anything, it'll probably screw up the pistons big time.
It is for this reason alone that shows these fans to be a pointless waste of money. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Mar 18, 2005 - 8:21 PM
well to get one to work properly you would need to retune your vehicle same as adding any forced induction product onto a vehicle, but you also need to reevaluate your onboard electrical systems, if the fan was made with a high pressure ratio in mind the amperage draw from it would be huge... thought needs to be put into an elecrical unit same as any other form of FI system... this is why you do see proven results of these sometimes from companys who have put real thought into actually developing one, now i highly doubt you will see one of these developed kits fly through ebay, but it can be done and it is out there, but its much more than sticking a fan into your intake and running the power and ground to your battery, i have yet to see one with a proper VFD, now that would be sweet... you can set up the parameters so that the VFD speeds up and slows down the fan depending on throttle position and it would work much like a supercharger, only using an electric draw instead of mechanical draw... i dont know if this has been done yet or not, but thats actually a pretty damn good idea...
Mar 18, 2005 - 8:57 PM
Thanks for the feedback everyone. Now I know never to buy the piece of crap Electric Supercharger.
Aug 22, 2005 - 3:10 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) |
all of the electric superchargers on ebay are crap.....however the e-ram electric supercharger is a decent mod. it will produce up to 2 psi for about a true 20+ hp gain for around $600..not to bad.. also there is the Thomas Kinght electric turbo that will give you a great deal HP gain at 6psi. .. however this system has many down sides to it.....only last for 15 seconds at a time and uses alot of battery power
Aug 22, 2005 - 3:50 PM
new idea.....leaf blower....runs on gas independantly controllable
Aug 22, 2005 - 3:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I got one, I never hooked it up though. I do believe in ram air. the claims of 20+hp are crap. Mine gave me 100hp
Aug 23, 2005 - 1:37 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Besides there is no such thing as centrifugal force...anyone with any type of physics knowledge, which would be necessary to build an effective electric supercharger, would know that centrifugal force isn't an actual force. Anyways, not necessary to go into more on that, just know that if you plan to buy an electric device such as this, it needs to be purchased from a reputable company that shows you actual data of the hp yields, otherwise it's not worth even thinking about. Welcome to the car world drew!
-------------------- 95 Toyota Celica GT
Aug 23, 2005 - 2:32 AM
Enthusiast ![]() Joined Apr 12, '05 Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Aug 22, 2005 - 3:50 PM) new idea.....leaf blower....runs on gas independantly controllable [right][snapback]326949[/snapback][/right] Dude your giving away my secret project =/ |
Aug 23, 2005 - 2:47 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
I have a short video of that, a guy installes a leaf blower up to his v8 and give it a try.
Aug 23, 2005 - 6:26 AM
your goin to tell us his and not what happened?
tell tell |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:50 PM |
