> more red in the interior *w/write up*, light around key
post Mar 19, 2005 - 1:03 AM
juBz86
Joined Aug 18, '04
From NJ
well i decided to change the light around the key hole from green to red. here are some pics. in the pics it came out a little orange, but if you seen it in person its red!! it was extremely easy to do!! i can do a write up if you guys want.
This post has been edited by juBz86: Mar 21, 2005 - 12:15 PM
post Mar 19, 2005 - 1:04 AM
Mynzeyes
From Franklin/Nashville, TN
i don't have that light...frown.gif.
looks good though. smile.gif.
AIM==Mynzeyes
post Mar 19, 2005 - 1:40 AM
juBz86
Joined Aug 18, '04
From NJ
really??? did you check?
post Mar 19, 2005 - 1:53 AM
Mynzeyes
yep yep. mine had all the options too from what i understand. iono. someone told me you can get them from the yota dealer for about 30 bucks or somethin...don't think it's worth it. but that's pretty neat. smile.gif.
AIM==Mynzeyes
post Mar 19, 2005 - 1:59 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
that's cool man! if you could do a quick writeup that'd be sweet. i need to change mine to blue.
is it a 194 bulb in there? or something else?
This post has been edited by Zimluura: Mar 19, 2005 - 2:12 AM
post Mar 19, 2005 - 2:28 AM
blackbullet
Joined Jul 21, '04
From Fresno, CA
as for mine..i colored it permanent red...i did blue before and looks really nice..but my guages are red and i also colored my ac and all the little stuff red so it goes...but i just used permanent marker....i tried a little LED blue bulb in there and looks really nice...
post Mar 19, 2005 - 8:52 AM
juBz86
Joined Aug 18, '04
From NJ
yea theres a little orange bulb w/a condom on it. its smaller than a 194. there are a lot of ways you could change the color of the bulb. i'll post i little write up later. promise biggrin.gif
post Mar 19, 2005 - 10:48 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(Mynzeyes @ Mar 19, 2005 - 1:04 AM)
[right][snapback]259348[/snapback][/right]
HaHa .. i didnt have it eaither, but i found one at the junkyard an jacked it. I put it in, an wired it up, but the bulb blew once i installed it.. an havnt replaced it sence, that was bout year ago. rolleyes.gif
post Mar 19, 2005 - 2:52 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
hey have you changed the light on your door panel switch? I cant seem to get that thing apart without breaking the window lock button.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Mar 20, 2005 - 3:30 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
QUOTE(juBz86 @ Mar 19, 2005 - 8:52 AM)
[right][snapback]259414[/snapback][/right]
cool, thanks. but if you're bussy, no worries. i read another post that said it was a 74 bulb. my main question is: do you need to use that crazy acc key setting (the shop manual i just got said something about this) to take the ignition out? or can it be disassembled (enough) without putting the key in the ignition?
thanks
post Mar 21, 2005 - 12:15 PM
juBz86
Joined Aug 18, '04
From NJ
ok sorry for being mad late with this!
first thing. pop off the the plastic piece that covers the ignition keyhole.^^VV
then look under the keyhole for a small screw.^^
pull off the clear plastic piece which should be connected to the bulb^^
twist off the bulb and you're left with is the plastic piece (you might want to take off the green condom)^^
i ended up makeing a little enclosure out of red divider tabs. you could take out the bulb. i dont know if they make the bulbs in different colors but you take it out to napa or somewhere and check if they make them in different colors.
o yea then just put every thing back 2gether.
post Mar 21, 2005 - 12:21 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
just to let u guys know i think thats a 74 bulb.
Team 6gc 2005
post Mar 21, 2005 - 12:22 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
http://www.superbrightleds.com/1157.htm
carries them in 4 different colors led.
Team 6gc 2005
post Mar 21, 2005 - 1:36 PM
initialdrift55
Joined Sep 23, '03
From Miami,FL
sweet looks pretty easy i think i might do this...i want it in blue..i gotta find the how-to so i can do the cooling panel and dash n stuff
post Mar 22, 2005 - 12:29 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
I have to take my dash apart anyway so im doing it. The cig lighter is easy to change the light....just twist the side connector and light pops out. dont bother with the lighter itself, i had to clean mine cuz it was so dirty and it was a bastard to take apart.
does anybody know if the celica comes stock with an ignition light bc my gt is lit up and i just noticed that my st didnt, either it went out or it doesnt have one.
Jubz86, did you change your ac unit to green also? i am wondering how i disconnect the cables from it (one is such a pain).
I can post pics if naybody wants.
-97 Celica ST
(GOT LIFT?)
post Mar 22, 2005 - 12:40 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
thanks a bunch. that's an awesome writeup.
post Mar 22, 2005 - 2:42 AM
tomazws
Joined Oct 30, '04
From So Cal
Thank you for that awesome write up!
post Mar 22, 2005 - 2:56 AM
droptopGT
Joined Apr 12, '04
From Nj Team 6gc
Team 6gc 2oo5
post Mar 22, 2005 - 3:09 PM
Nemises
Joined May 6, '04
From antioch CA
nice. Ha mine burnt out so long ago I actually forgot those light up at all.
post Mar 22, 2005 - 3:29 PM
juBz86
Joined Aug 18, '04
From NJ
its way better than that suckie stock green! glad everyone found it useful
Lo-Fi Version Time is now: September 22nd, 2026 - 1:47 AM
