Mar 20, 2005 - 1:01 AM
![]() Enthusiast ![]() Joined Sep 24, '04 From Kitchener, Ontario Currently Offline Reputation: 2 (100%) |
Well my clutch is in need of replacement soon, and I have been doing some research on which types there are and what kind suites my needs. However I’m a little lost on which one I should choose.
For my price range I am looking into the Centerforce Clutches. But I am not sure which one to go with, the stage 1 or the Dual Friction. From reading previous posts it seems that you suggest the Dual Friction for applications that have boost added on. Then the stage 1 for cars that are more stock. So I duno if I should get the Dual since I don’t plan on adding any type of boost for a year or two. I'm looking at the Burien kit by the way, if that helps. So should I get the stage 1, and would it hold for that kind of boost, or should I just get the Dual? Also I see that there is no Throwout Bearing with these kits. Do I need to order a Centerforce one or would a Toyota OEM one work? Thanks a lot for your time and help everyone This post has been edited by CanadaCelica: Mar 20, 2005 - 2:33 AM |
Mar 20, 2005 - 2:43 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
Just get an ACT, i love it, others love it. 23% more hold than oem, very nice, very nice
-------------------- ![]() The most important lesson I learned from Karate-Dô Kyôshan – “You can not be what you do not believe you are” |
Mar 20, 2005 - 11:57 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
New OEM would be OK, Stage 1 is plenty, ACT also ok, just remember, the clutch is currently the weak link in the driveline, under HARD driving, when something needs to give, better for the clutch to slip than a trans gear, differential or axle failing,,,much easier and cheaper to fix. probably wont matter with a relatively stock engine, just a note of forewarning if you do boost...
( BTW I learned this lesson the hard way,,,) |
Mar 20, 2005 - 7:18 PM
Thanx for the replies, ill more than likely go with the stage 1 so that i dont chance screwing up more expensive parts for when i look into boosting.
| Lo-Fi Version | Time is now: September 14th, 2026 - 12:15 PM |
