Mar 23, 2005 - 4:04 AM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
On some of the CT26's, I see that there's two vacuum ports on the wastegate.. What's the other port for?
Mar 23, 2005 - 4:51 AM
Are you talking about the wastegate actuator? The wastegates inside.
Mar 23, 2005 - 8:59 PM
Oops.. So I'm dumber than I thought..
Mar 24, 2005 - 10:26 AM
that peice you are talking about is the wastegate ACTUATOR. thats what operates the wastegate. the two nipples are for the hoses that connect there and operate the wastegate. one goes from the turbo to actuator, the other goes to the vsv is it super? im not exactly sure of the name, haha i dont have a 3s, i just know what it does..lol
on a 5sfte application, the boost controller of your choice goes between the line from the turbo to actuator and the other line gets capped. i know that for certain. lol -------------------- Former Team 5SFTE pro member ;)
Mar 24, 2005 - 11:54 AM
Yeah your right. The second line goes to the VSV.
Mar 24, 2005 - 12:43 PM
It is called the "T-VSV". For what its worth, it is a mechanism that allows stock boost to go from 7psi to 11.5 psi under the right conditions (ambient temperature being one). When you get a ball and spring manual boost controller, you should disable the T-VSV. You do not have to disable it with the other kind of MBC. I am not sure about EBC's.
Mar 25, 2005 - 1:44 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
why would that end need to be capped off of the actuator?
Mar 25, 2005 - 6:44 AM
because when you use a MBD you have to diable the factoy t-vsv. is kinda like the "stock" boost controler.
on a 5sfte application, we dont have a t-vsv, so we dont need that line. -------------------- Former Team 5SFTE pro member ;)
Mar 25, 2005 - 10:46 AM
You dont cap off to the actuator, you cap off FROM the actuator.
Mar 27, 2005 - 11:49 AM
ok so let me get this straight. there are two pipes comming from the top of my actuator. one of the pipes goes to the turbo housing. and the other pipe what does that do.. does that get hooked up to a vacum line or does that pipe get capped off??
Mar 27, 2005 - 12:50 PM
if your running a 5sfte, you cap the other line off.
Mar 27, 2005 - 5:21 PM
allright thanks pressure
Mar 28, 2005 - 1:52 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
how do you know what side to cap off
Mar 28, 2005 - 7:55 AM
QUOTE(urbandork @ Mar 28, 2005 - 2:52 AM) how do you know what side to cap off [right][snapback]263050[/snapback][/right] the one the faces at the turbo you use for your MBC the one that points away fromthe turbo gets capped. -------------------- Former Team 5SFTE pro member ;)
Mar 28, 2005 - 10:33 AM
Why do I think the same questions been asked 4 times and been answered 4 times in this thread.
Mar 28, 2005 - 3:27 PM
cause it has..
Mar 30, 2005 - 1:45 PM
beacuase maybe it's unlcear and we want to be certain it's right. and we aren't arrogant people
Mar 31, 2005 - 11:56 AM
Enthusiast Joined Mar 31, '05 From Northern England. Currently Offline Reputation: 0 (0%) |
if the engine is 3sgte, the pipe from the turbo to the actuator is where a manual boost controller goes, the actuator to Tvsv gets blanked.
if you have a 5sfte then just blank from the actuatuor away from the turbo and fit a boost controller in between turbo and actuator. the actuator decides how long and when to open the wastegate, the wastegate allows the turbo to spool. you dont want the stock bleed valve anyway as its pants, a mbv is better - a electronic controller is better still. This post has been edited by carlosfandango: Mar 31, 2005 - 11:59 AM -------------------- see my gallery at http://www.gt4oc.net/owners/owners_page.php?owner=2938
90 GT4 JDM 270bhp 89 GT4 UK Carlos Sainz Engine and Tranny - project 87 GT Convertible, 3SGE powered with nitrous, 205bhp. |
Mar 31, 2005 - 1:06 PM
good info carlos!!! thanks
| Lo-Fi Version | Time is now: August 27th, 2026 - 4:38 PM |
