> intercooler pipe to inlet/outlet, How does it effect?
post Mar 25, 2005 - 12:15 AM
urbandork
Joined Jul 16, '04
From Los Angeles
On my turbo set up im running 2" pipe.
The intercooler im looking at has a 2.5 inlet/outlet.
My question is what effects will i see by running an intercooler with larger inlet/outlets then the pipe that im running.
Should i see a big diffrence and if so in what presure drops, lag, ect, or will it not really matter.
post Mar 25, 2005 - 12:48 AM
Sev408
Joined Dec 4, '03
why not just change out ur piping so its correct. unless you already bought it.
only thing i could see happening is less air flow but not by much. i really dont see it causing any problems.
user posted image hows it taste motha f*cka
post Mar 25, 2005 - 1:49 AM
urbandork
Joined Jul 16, '04
From Los Angeles
Yup already started to buy 2 inch pipe.
But if i shouldnt run into n e pressure loss or super lots of lag then ill just hook the 2 inch pipe up to the 2.5 inch intercooler inlet/outlets.
In my intro to aerospace class we studied airflow and stuff. And the way i see it as long as the inlet and outlet are the same size then the airflow rate should remain the same.
This is the idea behind intercoolers with different size inlets and outlets.
post Mar 25, 2005 - 1:54 AM
Sev408
Joined Dec 4, '03
the only thing i could see happening is the outlet side when the air comes form 2.25 to 2. but its such a small amount i dont see it effecting/affecting much.
post Mar 25, 2005 - 2:53 AM
urbandork
Joined Jul 16, '04
From Los Angeles
coolios.
post Mar 25, 2005 - 6:43 AM
yea that wont hurt ya...and DONT go to the bigger piping, that will only increse lag.
post Mar 25, 2005 - 11:39 AM
Rjb23
Joined Feb 8, '04
From KY
I'm running 2.5 piping with 3" inlet outlet on my IC.
post Mar 25, 2005 - 1:01 PM
damn rjb how big is your intercooler??
post Mar 26, 2005 - 7:59 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(presure2 @ Mar 25, 2005 - 6:01 PM)
[right][snapback]262227[/snapback][/right]
Its medium size, but its also for a 3sgte too, not a 5sfe.
post Mar 26, 2005 - 8:06 PM
just get the correct size reducers to got from 2.5-2in and youll be fine.
Lo-Fi Version Time is now: July 29th, 2026 - 6:20 PM
