> MAP sensor error, error code p0105
post Mar 25, 2005 - 5:34 PM
orvillescelica
During my emissions test, they found a check engine error P0105 - Manifold Absolute Pressure/Barometeric Pressure Circut Malfunction.
I dont know how long this has been around, since i have been ignoring my CEL since i did my trans swap. (The transmission shift solenoids are no longer connected)
Anyway, my car runs just fine and always has. Do you guys suspect its just a bad sensor? A wiring problem? Or something much more involved?
(I tried searching since i remember someone having a similar problem, but MAP is a three letter search)
post Mar 26, 2005 - 12:45 PM
TTE
Joined May 19, '03
From NJ
I have the same problem 'code105'. $280 from the dealer for a MAP sensor is too much so I went to junk yard and picked up five of those from different toyotas(including Celica). They all fit but every single one worked for a week and then died giving me the same code.
Go rigure out. I need BG book to test this problem.
post Mar 26, 2005 - 10:30 PM
orvillescelica
so for you it was a bad sensor? Thats good to hear. Im going to take out the sensor and test it tonight and see whats going on. If tis $280 for a new sensor thats ok, becuase for emissions tests, if the repair is over $150 then i get a waiver.
Lo-Fi Version Time is now: September 21st, 2026 - 9:32 PM
