> engine smoking?, i need help!!!
post Mar 31, 2005 - 11:02 AM
monky32
Joined Oct 19, '04
From orlando
hi guys!!!!
i need your help. i have a 1998 celica gt with 86000 miles but the car seems burning oil confused.gif . i checked today the oil level and i was two quarts below the normal and i just don't know why. my engine runs very strong but what could be wrong with it.
fyi: when i bought this car i found a very small leak in one of spark plugs holes so i took it to toyota and that problems was fixed. do you think this has something to do with what is going on right know.
thanks for your help!!!
any suggestion about what could be the problem
This post has been edited by monky32: Mar 31, 2005 - 12:39 PM
post Apr 1, 2005 - 2:00 AM
Newbie
Joined Nov 3, '04
From Colorado
Any smoke out the exhaust pipe? If so, what color?
post Apr 1, 2005 - 2:29 AM
monky32
Joined Oct 19, '04
From orlando
no i didn't see any smoked coming out the exhaust. i will check for leaks but i am almost sure i don't have one. somebody told me that between oil changes the car can "burn" one quarter but it doesn't make sense to me because the miles of my engine.
any suggestions?
post Apr 1, 2005 - 3:16 AM
macavely
Joined Nov 4, '02
when are u checking the oil after that engine has be one for a few minutes ? or when its cold?
deppending on the temp on the ening u will have diffrenet readings .... remebre o engine that has been running for a while .. will read as if it has less oil cause the oil has sprayed all around inside the eingen ... if it was bruning oil u will notice that the coior of the oil goes from clear to black faster then normal ...
post Apr 1, 2005 - 11:05 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
It could be a number of things. Leaky drain plug gasket, leaky valve cover gasket, leaky distributor gasket, bad head gasket, leaky oil pan gasket... I'd stay away from the dealer. Whenever I see drops of fluid on my garage floor I just take it to my mechanic and have him find whatever seal is leaking and replace it. Just check your phone book for a toyota specialist. You typically won't get robbed like you will at the dealer. The dealer always tries to talk me into some bullsh** I just had replaced or replaced myself! And half the time I discover the guy doing the talking at the dealer isn't even a mechanic!!! (Note to everyone: I had those experiences at Toyota of Santa Maria out in Cali. Every time I went in there it was a complete joke.) thumbsdown.gif
post Apr 1, 2005 - 1:50 PM
monky32
Joined Oct 19, '04
From orlando
mac i checked my oil when my engine was cold and showed that i had just barely a quarter of oil which doesn't make sense because i checked the floor for oil spots and i didn't find any. when i got my car had 60000 miles and i've been using syn oil since plus i don't race my car so i just don't understand why this is happening.
thanks for your replies!!!!
post Apr 1, 2005 - 9:43 PM
Newbie
Joined Nov 3, '04
From Colorado
Did you try a compression test?
post Apr 1, 2005 - 9:50 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
QUOTE(monky32 @ Apr 1, 2005 - 11:50 AM)
[right][snapback]265248[/snapback][/right]
Wait... a quarter of oil? Dude, the dipstick Lo to Hi range only covers about a quart of oil. If it is pegged on the bottom edge of Lo, then you are only one quart low. Just because it hits Lo doesn't mean you're running dry. It means you've burned one quart.
post Apr 2, 2005 - 3:38 PM
monky32
Joined Oct 19, '04
From orlando
QUOTE(94GT @ Apr 2, 2005 - 2:50 AM)
[right][snapback]265461[/snapback][/right]
is this correct? so how do i know if i am running dry or how many quarters do i have in my engine?
post Apr 2, 2005 - 5:27 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I hope you don't have any "quarters" in your engine. They weren't designed as a coin-op machine. Anyways if the oil line is right at "low" on the dipstick it's safe to say you are one "quart" low. If you have time let it set for about 15-30 minutes after you fill it with that one quart and you'll see the results on your dipstick.
post Apr 4, 2005 - 1:03 AM
monky32
Joined Oct 19, '04
From orlando
QUOTE(WannabeGT4 @ Apr 2, 2005 - 10:27 PM)
[right][snapback]265716[/snapback][/right]
thanks wannabe for your replie and thank god i don't have "quarters" in my engine(ESL). i added one pint of oil and you're right oil level is full but is it normal that my car is burning oil with 86000 miles confused.gif? is this normal in our cars? or my engine is runnig hot?
post Apr 4, 2005 - 1:33 AM
946thGenGT
Joined Oct 4, '04
QUOTE(monky32 @ Apr 4, 2005 - 6:03 AM)
[right][snapback]266183[/snapback][/right]
Over what period of time did you burn that much oil?
post Apr 4, 2005 - 1:56 AM
monky32
Joined Oct 19, '04
From orlando
QUOTE(946thGenGT @ Apr 4, 2005 - 6:33 AM)
[right][snapback]266189[/snapback][/right]
last oil change= 5000 miles i am using mobil one syn. i am just about to change my oil again maybe tomorrow.
post Apr 4, 2005 - 6:31 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
Very normal. Mine has been doing it consistently since I bought it with 100k on it.
post Apr 5, 2005 - 2:03 AM
monky32
Joined Oct 19, '04
From orlando
QUOTE(94GT @ Apr 4, 2005 - 11:31 AM)
[right][snapback]266247[/snapback][/right]
thanks guys for educating me.
Lo-Fi Version Time is now: August 23rd, 2026 - 6:30 PM
