Apr 1, 2005 - 11:33 AM
Enthusiast ![]() Joined Sep 14, '04 From miami Currently Offline Reputation: 0 (0%) |
should i put tein coilover kit that has 16 level of highering and lowering or should i put hyb shock and trd lowering spring
Apr 1, 2005 - 4:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
TEIN!!!!!!!!!!!!!!!!!!!!!!!!!
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 1, 2005 - 6:14 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
Tein doesn't have 16 levels of height. It has 16 dampening settings.
Apr 1, 2005 - 7:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
If you have the money, go with the Tein SS. Best set for out car afaik
Apr 13, 2005 - 1:59 PM
Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
i went with KYB gr-2 struts and i couldnt ask for anything better
Apr 13, 2005 - 2:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
if you do not plan to race your vehicle you are wasting your money getting any type of multi adjustable suspension setup. nearly any other setup you run will increase tire wear, and is not necessary unless you plan on needing the adjustability. if you are looking for just something with dampening adjustability to go between a stiff sporty ride and something softer for rougher daily roads just get lowerings springs and a set of adjustable shocks.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
| Lo-Fi Version | Time is now: August 25th, 2026 - 7:18 AM |
