> Motor Mount Removal Problems
post Apr 3, 2005 - 7:53 PM
I'm trying to change crossmembers in my Celi, but now I'm horribly stuck after trying to get the crossmember out for a good couple hours.
I got the bolts out of the front and rear mounts, and loosened up everything on the crossmember. In the attempt to get the rear tranny mount to move up so that the bolts on it would clear the crossmember, the mount got twisted sideways and is now completely stuck. I tried everything, but nothing seems to work to get it loose. frown.gif
Here's some pics:
Anyone got any ideas? By the way, if my new crossmember and mounts don't bolt up, I think I'm gonna torch the Yelli Celi. I absolutely HATE the mechanical aspect of working on cars.
Attached Image Attached Image
- Coomer   Motor Mount Removal Problems   Apr 3, 2005 - 7:53 PM
- - Bigmeanbulldog55   I'd say to loosen another mount, or take anoth...   Apr 3, 2005 - 9:10 PM
- - lagos   put a floor jack under the tranny and jack it up. ...   Apr 3, 2005 - 9:12 PM
- - rjbibeau   ohh i remember that thing when i was tapping my oi...   Apr 3, 2005 - 10:55 PM
- - Coomer   I already unbolted all three tranny mounts and jac...   Apr 3, 2005 - 10:57 PM
- - Jeremy1210   off the question, but why are you changing your cr...   Apr 3, 2005 - 10:59 PM
- - Coomer   QUOTE(Jeremy1210 @ Apr 3, 2005 - 7:59 PM)off ...   Apr 3, 2005 - 11:01 PM
|- - rjbibeau   any progress on that mount coom   Apr 4, 2005 - 1:03 PM
|- - rjbibeau   why did you have to drop your rack for?   Apr 4, 2005 - 1:07 PM
- - Rjb23   I had to drop the steering rack to get mine out.   Apr 3, 2005 - 11:48 PM
- - easternpiro1   did you try using colorful and versitile profanity...   Apr 4, 2005 - 11:45 AM
- - lagos   coomer, looking at your pic again... it seems like...   Apr 4, 2005 - 1:21 PM
|- - Rjb23   QUOTE(lagos @ Apr 4, 2005 - 6:21 PM) if that ...   Apr 4, 2005 - 3:20 PM
- - Supersprynt   Whats happening is the mount is being seperated, t...   Apr 4, 2005 - 1:36 PM
- - nik   if you have an engine hoist that will help alot   Apr 4, 2005 - 1:58 PM
- - Coomer   Art, I already took off the front two bolts on the...   Apr 4, 2005 - 2:02 PM
- - Coomer   Does it mess up the alignment or anything to lower...   Apr 4, 2005 - 3:23 PM
- - lagos   QUOTE(Coomer @ Apr 4, 2005 - 3:23 PM)Does it ...   Apr 4, 2005 - 3:33 PM
- - Coomer   I decided that since we broke the rear mount attem...   Apr 5, 2005 - 12:49 AM
- - Hanyo   poor gasoline on it and light that mount on fire.....   Apr 5, 2005 - 1:46 AM
- - Drocay   wow, coomer u butchered it.   Apr 5, 2005 - 2:35 AM
- - Coomer   QUOTE(Hanyo @ Apr 4, 2005 - 11:46 PM)how are ...   Apr 5, 2005 - 2:25 PM
- - lagos   do you know if that is the same mount as the 5sfe ...   Apr 5, 2005 - 3:37 PM
- - Coomer   I don't know...I could make my own polyurethan...   Apr 5, 2005 - 4:36 PM
Lo-Fi Version Time is now: May 20th, 2026 - 1:09 PM
