> Strange Observation..., Can anyone tell me whats going on?
post Apr 7, 2005 - 10:14 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
So I'm comming home from a barbeque yesterday (beautiful weather) and no sooner did I pull in my driveway, but I heard a quiet ticking sound from my engine. So i popped the hood with the motor running and it sounded like it was comming from the alternator so I wasn't too worried.
But then I realized that the sound was a little more distinct, and that the cylinder seemed to be ticking at idle. So even though the engine was kinda hot from the highway, I felt on top of the spark plug wires and cylinders 2 and 4 felt like they were ticking really hard against the plug or something.... like a *tick tick tick* against my hand. But on cylinder 1 and 4, there was no such ticking that you could feel when you touch the spark plug wire. Pretty wierd, huh?
Any idea what this could be? Only thing i could think of is a cylinder colliding with the plugs in two of the cylinders or some ticking valves or something. From what I can tell its not my new spark plugs, because they were recently replaced with new Bosch plugs but are pregapped and all tightened the same. Could somebody check to see if their motor does this at idle?? If not, do you think theres something really wrong and worth getting checked out?
post Apr 7, 2005 - 10:26 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
mine does that after a long drive. I just figure something is cooling down or its a belt
post Apr 7, 2005 - 10:32 PM
I seriously doubt your pistons are hitting your plugs...you'd have severe damage and louder noises I think.
My guess would be valves.
post Apr 7, 2005 - 10:45 PM
fastgt
Joined Feb 13, '03
From California
oops sorry
This post has been edited by fastgt: Apr 7, 2005 - 10:45 PM
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
fastgt
Joined Feb 13, '03
From California
vavle slap...that would suck....um maybe its normal check your plugs if theyre ok you may wanna check the valves...pray thats not it
post Apr 7, 2005 - 11:18 PM
Silver94CelicaOw...
Joined Oct 13, '02
Yea I need to check the plugs to be sure, but it ran fine on my way home that day though. However, if somebody else could check theirs at idle after like a half hour drive, I would appreciate it.
post Apr 8, 2005 - 9:07 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
Mine did that. The spark plug was backing itself out. I just retightened it and it was good to go.
post Apr 8, 2005 - 2:24 PM
do you mean when the motor is running or after you turn it off?
it its running, it could be just simply your injectors ticking.
if the motor is off, then its all the exhaust metal cooling off.
post Apr 8, 2005 - 10:51 PM
Silver94CelicaOw...
Joined Oct 13, '02
Hey 94GT....good call man. biggrin.gif I came home tonight and checked all the plugs again, and the two cylinders that made noise at idle all had somewhat loose spark plugs. So I just torqued down all the plugs again after inspecting them all and it did the trick. Im relieved....thanks guys. smile.gif
post Apr 9, 2005 - 11:32 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
No problem, bro, glad I could help
post Apr 10, 2005 - 12:42 PM
spunky393
Joined Apr 22, '04
From illinois
Our toyota engines are made to prevent valve slap from the cyl. That way, if the timing belt breaks, that's the only thing that has to be replaced. On a honda engine, if the timing belt breaks, you're screwed. I can't remember the tech. name, but i think it's called free floaters.
post Apr 10, 2005 - 8:45 PM
mikew04
Joined Feb 19, '04
From austin tx
QUOTE(spunky393 @ Apr 10, 2005 - 5:42 PM)
[right][snapback]269091[/snapback][/right]
non-interference engine, thats what we have
higher compression engines tend to have interference engine, and yah, if the belt breaks, there goes your valvetrain
if ours breaks, engine just shuts down
post Apr 10, 2005 - 9:50 PM
spunky393
Joined Apr 22, '04
From illinois
wonderful japs
Lo-Fi Version Time is now: September 15th, 2026 - 8:48 PM
