> New car, Suggestions
post Apr 11, 2005 - 2:05 PM
StaticKnotX
Joined Sep 5, '04
Decideing against engine swapping a 3SGTE into my 96 Celica ST or just selling it and buying a 3,000$ 1st gen 6bolt Talon TSi AWD.
What would the best bang for the buck be? I just want to do 13's and I'll be happy.
Also, on a scale of 1 - 10, how difficult is the engine swap from someone that doesnt know much about engines in general? I really dont know what to do for my next car. This 110 horsepower isnt cutting it anymore.
Replies (1 - 19)
post Apr 11, 2005 - 3:15 PM
Dont do a swap yourself if you dont know what your doing. I personally cant rate an engine swap when I dont know what you do. To me the engine swap was probably a 7 if 10s hardest. But then again I think fiberglass work rates 12 because IDK what im doing with it. It's all relative.
post Apr 11, 2005 - 3:31 PM
It sure is relative...I'd rather make a sub enclosure entirely out of fiberglass than change a motor mount.
As far as bang for the buck, the Talon will be faster for less money. But DSMs are notoriously unreliable.
post Apr 11, 2005 - 3:53 PM
cough, crankwalk, cough.
post Apr 11, 2005 - 4:01 PM
nik
Joined Sep 30, '02
buy the talon and do a complete rebuild with all the goodies
headwork
better pistons rods crank etc
new clutch
new axles that can stand up to 500whp
bigger turbo system
stand alone
post Apr 11, 2005 - 4:03 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
"you have enough noz to blow yourself to the moon..."
-DMC
post Apr 11, 2005 - 4:10 PM
Don't forget a new tranny too if you get the DSM, and then another for a spare once it breaks.
post Apr 11, 2005 - 4:33 PM
nik
Joined Sep 30, '02
QUOTE(Coomer @ Apr 11, 2005 - 2:10 PM)
[right][snapback]269652[/snapback][/right]
have custom one built with new gearing and a warrenty
post Apr 11, 2005 - 5:43 PM
StaticKnotX
Joined Sep 5, '04
QUOTE(Supersprynt @ Apr 11, 2005 - 8:53 PM)
[right][snapback]269643[/snapback][/right]
Wont happen lol, getting a 6bolt, 1990-1993 DSM. No CW like 7's
I was thinking that as well, get the 6bolt, do all the tune up and repair/maintence in the book it says to do. Then rebuild the thing, so it doesnt break on me. Im going to stick with the stock 14b turbo and not going above the stock 16 psi.
Hoping to buy a virgin and just do these mods:
The free mods, remove the air restrictor, etc...little things
New exhaust manifold (stock one is probably rusted all to hell)
New 3" turbo catback
High flow catalytic converter, with a higher flowing unit
2.5" High flow downpipe
Better flowing 02 sensor housing
190 fuel pump
K&N intake filter, and new hard intake pipe
Boost gauge
Manual boost controller
Short shifter
then a new performance clutch when the stock one goes out
This post has been edited by StaticKnotX: Apr 11, 2005 - 5:50 PM
post Apr 11, 2005 - 6:05 PM
prompt
Joined Jun 26, '04
From Biddeford, ME
Bang for buck is easily the talon. With the 6bolt ur pretty much good to go. But I would get a new clutch for it. Preferably a 2400. Also check the compression before you buy get it to make sure its equal all across.
Oh ya if ur going to get a new exhaust. The N1 is easily the best way to go. If ya want to know more about the DSM hit up.. www.dsmtuner.com
This post has been edited by prompt: Apr 11, 2005 - 6:06 PM
post Apr 11, 2005 - 6:46 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
dsm power. easy too mod and affordable
post Apr 11, 2005 - 7:18 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
Can someone explain this 6 bolt 7 bolt stuff?
- Ryan
aim: rkgreen04
post Apr 11, 2005 - 7:22 PM
95sweetness
Joined Apr 23, '04
From illinois
totally the dsm. They r incredibly easy to mod n with the stock 14b turbo you can hit the 12s. I think theres some1 on the board who did high 11s wit the stock turbo. They r great car n sound mean. but like each car u build somethin always tends to break since its old n used....n ill ask my bro in law bout da 6 bolt thing...im totally not sure bout it easier
This post has been edited by 95sweetness: Apr 11, 2005 - 7:22 PM
post Apr 11, 2005 - 9:19 PM
StaticKnotX
Joined Sep 5, '04
wish I could explain it, but im tired lol. Def. going with the DSM. Friend just got back his ECU with DSMLink and has it set so his rev limiter is his launching rpm. ****ing pulls, 1st gear was done in a second and we were already hitting 40. Def. going with DSM. AWD > all
His isnt tuned at all, but is modded enough to where he can support 20 psi. I forget what turbo he has, ill let you know when I find out
This post has been edited by StaticKnotX: Apr 11, 2005 - 9:20 PM
post Apr 11, 2005 - 9:24 PM
StaticKnotX
Joined Sep 5, '04
QUOTE(prompt @ Apr 11, 2005 - 11:05 PM)
[right][snapback]269694[/snapback][/right]
already a member, name is PurpleHaZe. I never post right now though, just soaking up the info for when I get mine. Also I checked the compression on a talon I was looking at, 150 across. Any good?
This post has been edited by StaticKnotX: Apr 11, 2005 - 9:27 PM
post Apr 12, 2005 - 4:50 PM
prompt
Joined Jun 26, '04
From Biddeford, ME
150 across for a 1st gen is damn impressive considering how old they are.
As for the 6-bolt its similar as to the fact it will get crank-walk as much as any type of car would. The 7-bolt was internally built weaker, but still a very powerful engine.
Also check for the turbo seals. That is pretty much the only problem on them, anmd they dont cost much to replace anyways. BTW how many miles are on the car?
post Apr 12, 2005 - 5:36 PM
StaticKnotX
Joined Sep 5, '04
QUOTE(prompt @ Apr 12, 2005 - 9:50 PM)
[right][snapback]270129[/snapback][/right]
130,000. 80,000 on the rebuild, 80k on the new stock turbo..14b, all maintence has been done to it. Never drives it hard and its his daily driver. Asking 3,000. Im more then likely going to get it, cause as a added bonus, its only 30 miles away
This post has been edited by StaticKnotX: Apr 12, 2005 - 5:42 PM
post Apr 12, 2005 - 8:15 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
wouldn't changing the heads on a 1G to a 2G be pretty beneficial?
anyways, GL
i'm stuck w/ my celi since my rents got me by the balls...so it's save $ time
post Apr 12, 2005 - 11:30 PM
StaticKnotX
Joined Sep 5, '04
QUOTE(Consynx @ Apr 13, 2005 - 1:15 AM)
anyways, GL
[right][snapback]270225[/snapback][/right]
Plus, I like sleepers...people look at 1st gens and think they're pisses of ****. They laugh when you rev at them, then you blow them away. Priceless
post Apr 13, 2005 - 12:30 AM
prompt
Joined Jun 26, '04
From Biddeford, ME
what's funny tho is that a 14b isn't stock. Its a upgrade from the stock. The stock turbo on eclipses\talons\lasers is the t25.
One last thing is to ask when he changed the timing belt just in case. If he has changed it recently then ur pretty much all set to go.
First thing you should buy for the car though is a Greddy Turbo Timer. Cost less than $100 and it helps save the life of ur turbo very much.
Lo-Fi Version Time is now: August 31st, 2026 - 8:55 PM
