Apr 11, 2005 - 4:48 PM
Enthusiast ![]() ![]() Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
Alright the codes that pulled are:
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem I'm getting around 12-15mpg and shes sluggish as hell. Idle VAC is 18-19 I've recently got a new MAP sensor (which was confirmed in working condition), but the CEL was still triggered. The shop says that if it is a good sensor, then it has to be the wiring harness or ECU. Also, I recently got a replacement header, which had its secondary O2 sensor bung stripped out. So I spliced the primary and secondardy lines and plugged the hole, which I've heard is a common fix when getting a performance header that only has the primary bung. This did not pull any O2 codes, but I wasn't sure if this was dampering my mpg/performance. Has anyone spliced their O2 wires successfully? Any help would be hot...thanks. This post has been edited by erics1one: Apr 18, 2005 - 12:51 PM -------------------- ![]() |
erics1one CEL Codes - 2 * MAP Sensor related Apr 11, 2005 - 4:48 PM
lagos why did u buy a new map sensor? u still have the o... Apr 11, 2005 - 6:48 PM
erics1one Well I didn't buy a new map sensor. I got a u... Apr 11, 2005 - 6:58 PM
erics1one The splicing seems to be a straightforward process... Apr 12, 2005 - 11:19 AM
lagos your car is obd2, so maby the same splicing wont w... Apr 12, 2005 - 2:32 PM
erics1one QUOTE(lagos @ Apr 12, 2005 - 12:32 PM)your ca... Apr 12, 2005 - 3:51 PM
erics1one Tested the MAP Sensor connection. Voltage reading... Apr 18, 2005 - 1:03 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 4:19 AM |
