Apr 12, 2005 - 9:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
First off let me say that I need this fixed ASAP because this car is my ONLY transportation to classes and work so ALL input on this is EXTREMELY helpful!
Car: 94 GT hatchback, manual transmission, 235k miles Symptoms: -At idle, rpms jump/bounce between 400 and 1000 rpm. Can feel a physical shudder/vibration when rpm drops. Almost as if it's about to die -While accelerating, the car will hesitate and lurch forward a bunch. Seems to get better if I really hammer the gas pedal. -Hard to start, sometimes have to crank for almost a fill minute before it will start What i've replaced: -Distributor -Plugs and wires -Battery is good to go -Fuel FILTER I have a feeling that after nearly a quarter million miles, my stock fuel pump is finally giving up. When I had my alignment done, I asked what this could be and he said that it's most likely the fuel pump but it could be a clogged fuel filter. He said to buy more time I should change the fuel filter, which I did. It helped a little until just now. Does anyone have any input on whether this sounds like a fuel pump thing? If so, what would be a reasonable price for parts and labor to have it fixed by a mechanic? Thanks, -Josh |
gt_driFFter Daily Driver about to bite the dust! Apr 12, 2005 - 9:04 PM
Clipsetuner What I had happen is my TPS (throatle Positioning ... Apr 12, 2005 - 9:59 PM
hellsyphon Also try the Idle Air Control Valve (IAC). My car ... Apr 12, 2005 - 10:31 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 15th, 2026 - 5:04 PM |
