> Rust!!! (56k warn), help me!
post Apr 15, 2005 - 3:52 PM
Mike
Joined Oct 22, '02
From Toronto
Just got through a long winter and I was washing my car yesterday and noticed rust!!! What should I do?!?! Please help me out, I already got touch-up paint from toyota.. here are some pics...
This post has been edited by Mike: Apr 15, 2005 - 3:53 PM
Replies (1 - 5)
post Apr 15, 2005 - 4:12 PM
celicaboy04
Joined Sep 13, '04
From CA, USA
You have to sand the rust spots to the bare metal surface removing it ALL. If it the rust has eaten completely through the metal, you will have to rig a patch (probably would involve some slight welding if you have to patch it) then you would grind the welding spots off, bondo if there are low spots (no deeper than 1/8 of an inch), sand everything smooth, then prime and seal it and then touch up paint.
If you just touch up over the rust it wont do anything, only hide the damage for a little while, and risk worsening the rust there is and possibly spread it.
This post has been edited by celicaboy04: Apr 15, 2005 - 4:13 PM
Armed? Armed with what?
Oh I dunno, colorful language, bad breath, a feather duster...Whatta you think theyre armed with guns you tit!
post Apr 15, 2005 - 11:06 PM
welcome to the club http://www.6gc.net/forums/index.php?showtopic=23629
post Apr 17, 2005 - 11:42 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Yea Celicaboy is right. You need to sand the paint down to bare metal, I would also treat the metal with a product called OSFO or any rust eating chemical. Then prime it with a 2 part primer, spray a sealer, and repaint the door.
Chances are the rust was caused by a factory mistake in the paint job, or the door has had bodywork done in that area before and someone skipped a step. Hope it works out for ya.
post Apr 18, 2005 - 1:05 AM
tengys
Joined Aug 24, '04
From Saginaw, MI
i'm the club member too...mine got rust at the same places and the door too....... frown.gif frown.gif frown.gif frown.gif
post Apr 18, 2005 - 7:08 AM
Insanity-74
Joined Jan 9, '05
From Under the car
That looks like its going to be pretty well developed rust spread all along the wing, unless its an error on my monitor and it isnt as bad as it looks, I`d go for a new front wing. On the back, grind out as much as you can, all of it if possible or like already mentioned it will come back and just spread
Lo-Fi Version Time is now: June 25th, 2026 - 4:31 PM
