> Rear disk brake swap info, e-brake cable
post Apr 17, 2005 - 1:39 AM
how do i modify the e-brake cable so that it can fit on the st?
cause right now i have a ton of slack and its not pulling at all
and i'm using the GT cable right now
- playr158   Rear disk brake swap info   Apr 17, 2005 - 1:39 AM
- - AndyST4   I used the st upper part of the cable and the gt s...   Apr 17, 2005 - 3:00 AM
- - playr158   sable? can you define for me please? by sable ar...   Apr 17, 2005 - 5:24 PM
|- - AndyST4   QUOTE(playr158 @ Apr 17, 2005 - 5:24 PM)sable...   Apr 18, 2005 - 1:41 PM
- - Jeremy1210   i took a bolt cutter and just chopped off an inch ...   Apr 17, 2005 - 8:22 PM
- - playr158   ok so i can just cut it and then use a clamp to ho...   Apr 18, 2005 - 10:15 AM
- - AndyST4   I don't understand why some people get slack w...   Apr 18, 2005 - 1:52 PM
- - playr158   yea i have the upper st and lower gt its weird i ...   Apr 18, 2005 - 5:30 PM
- - Ve1Ls1dEvolutioN   can i use the stainless steel brake line kit from ...   Apr 18, 2005 - 6:44 PM
- - Coomer   Isn't there a but that adjusts cable tension u...   Apr 18, 2005 - 6:46 PM
- - playr158   yea you can adjust it there i have like 6-10 bolts...   Apr 18, 2005 - 7:12 PM
- - trdevelopment   i dont haqve slack i just cut the black plastic ci...   Apr 18, 2005 - 7:47 PM
- - defgeph   Sorry for being such a n00b. What do I need for t...   Apr 19, 2005 - 6:36 PM
- - playr158   hahahaha def you lmao yea you need a gt e-brake c...   Apr 19, 2005 - 6:45 PM
- - Ve1Ls1dEvolutioN   how bout converting my ST front to GT...snivesatgt...   Apr 19, 2005 - 8:48 PM
- - defgeph   Dan, Driving the honda has gone to my head. lol ...   Apr 19, 2005 - 8:54 PM
- - playr158   oh god the civic   Apr 19, 2005 - 9:25 PM
- - Digndoug   ok two questions Will the 5th gen celica rears wo...   Apr 20, 2005 - 10:20 AM
- - Drocay   yes on both.   Apr 20, 2005 - 10:23 AM
- - Digndoug   QUOTE(Drocay @ Apr 20, 2005 - 10:23 AM)yes on...   Apr 20, 2005 - 10:27 AM
- - Jeremy1210   1 of mine were frozen, no bigge just got a new one   Apr 20, 2005 - 12:04 PM
- - playr158   personally just get ones from the junkyard and th...   Apr 20, 2005 - 12:53 PM
- - Coomer   Doug, Some STs(and maybe GTs/GT-Ss) are four-lug. ...   Apr 20, 2005 - 2:54 PM
- - playr158   guessing probably like 70$ or so a piece not ...   Apr 20, 2005 - 5:19 PM
- - MonsterBOX   how big of a diff do you all notice over st front ...   Apr 20, 2005 - 10:44 PM
Lo-Fi Version Time is now: May 18th, 2026 - 10:30 AM
