Apr 21, 2005 - 4:20 PM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
sup guys been thinking about getting some aftermarket fog lights. Just want to know how hard it is to install them and can someone walk me through the steps. Thanks in advance.
Apr 22, 2005 - 1:55 PM
Enthusiast ![]() ![]() ![]() Joined Feb 8, '05 From Cambridge, ON, Canada Currently Offline Reputation: 1 (100%) |
do you have stock ones you wanna sell???
-------------------- lissa | 1997 Celica Convertible
*My other ride is your boyfriend* ;) |
Apr 22, 2005 - 2:14 PM
The instructions tell you how to install them.
Apr 22, 2005 - 3:12 PM
They're not hard to install. I'd remove your front bumper so you can take off the crash-reinforcement bar, drill holes, and mount the fogs into that.
Then wiring is really simple...the fogs can be grounded to the bolts you use to bolt them in. Then you've got a relay that comes with the fog lights. One wire goes to ground(I'd just use the screw you use to bolt the relay into the metal part of the car), one goes to your switch, one goes to a fuse and then the battery and one goes to the two fogs. The instructions should have a picture and more details. -------------------- New Toyota project coming soon...
Apr 27, 2005 - 9:31 AM
Enthusiast ![]() Joined Apr 18, '05 From Temecula, CA Currently Offline Reputation: 0 (0%) |
i was going to put some aftermarket foglights too... i have the stock ones... but i want to change them...
is there any way i could just hook up the aftermarket ones to the stock electrical harness (so i could use the swicth for the stock fogs) ? |
Apr 27, 2005 - 12:33 PM
yeah...just wire them in...its only 2 wires, very simple hook up job
Apr 27, 2005 - 1:17 PM
can some one post up pics of their after market fogs. I want to see where you guys mount them
Apr 27, 2005 - 9:26 PM
Enthusiast ![]() ![]() Joined Apr 14, '05 From garfield hts. O-HI-O Currently Offline Reputation: 0 (0%) |
look in my profile i have some. they dont look bad other then there not hooked up! lmao the guy i bougt the car from a lil bit ago had them on but not hooked up, gona try and figure it out 2 marro
Apr 28, 2005 - 2:55 PM
cool can you take pics for me
May 19, 2005 - 10:25 PM
hey just got my fogs in the mail today. just wanted to know where to i put the relay. And there is this red wire and I dont know where it goes.
May 19, 2005 - 10:40 PM
Enthusiast ![]() ![]() Joined Jan 28, '05 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
QUOTE(celicaboston1983 @ May 19, 2005 - 10:25 PM) hey just got my fogs in the mail today. just wanted to know where to i put the relay. And there is this red wire and I dont know where it goes. [right][snapback]289281[/snapback][/right] red wire almost always = power...coonect it to battery or a switch or a fuse (IE headlight fuse)...black = ground -------------------- Speeding is only Illegal...
If you Get Caught |
May 19, 2005 - 11:12 PM
it has two red wires one has the ring to connect to the battery the other one is just a open wire. Im stupid when u say ground what do you mean. Thanks
May 20, 2005 - 12:29 AM
if you want them to light up with your headlights, put 85 to one of the headlight fuses in the engine bay fuse box. if you want them to light up with your parking lights, 85 to your side marker (splice into). This post has been edited by Batman722: May 20, 2005 - 12:33 AM -------------------- |
May 20, 2005 - 7:34 AM
so if i dont want them to light up with anything I can just leave it?
May 20, 2005 - 3:51 PM
QUOTE(celicaboston1983 @ May 20, 2005 - 7:34 AM) so if i dont want them to light up with anything I can just leave it? [right][snapback]289394[/snapback][/right] if you don't want them to light up, don't use any wires J/K wire them just like the diagram (use the switch to fully control them) -------------------- |
May 21, 2005 - 9:56 AM
thanks
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:15 PM |
