> 3sgte and aftermarket parts, ignition
post Apr 22, 2005 - 1:23 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
According to http://www.geocities.com/zegoat2000/THESWAP.html which has a ton of good info for a swap, the engine components you need are:
-the engine
-uncut wiring harness
-ecu
-ignitor
-ignition coil
-resistor pack
-maf unit
-top mount intercooler
My question is I know that you can get universal aftermarket ignition stuff. is there any reason you cant use this for the ignitor and ignition coil? im rather unknowledgeable about ignition in new cars.
Also, what is a resistor pack and what does it do? I searched on google and found nothing.
thanks for the info
brian
This post has been edited by CheesyLobster: Apr 22, 2005 - 1:24 AM
- CheesyLobster   3sgte and aftermarket parts   Apr 22, 2005 - 1:23 AM
- - CheesyLobster   please?   Apr 23, 2005 - 2:54 AM
- - presure2   resistor pack is for the injectors. i suppose you ...   Apr 23, 2005 - 7:54 AM
- - Supersprynt   Resistor pack contains 2 solenoids. One for the fu...   Apr 23, 2005 - 10:56 AM
- - lagos   *BUY A CLIP!* coil, the 5sfe one should work...   Apr 23, 2005 - 12:23 PM
- - CheesyLobster   thanks   Apr 23, 2005 - 11:24 PM
Lo-Fi Version Time is now: August 27th, 2026 - 2:37 PM
