Apr 25, 2005 - 7:02 PM
Enthusiast ![]() Joined Jul 16, '03 From Boise, Idaho Currently Offline Reputation: 0 (0%) |
My amp was installed by myself $250 save at least. and I mounted it on top of my sub box its an MTX 801D monoblock with no fans
This post has been edited by chicklover345: Apr 25, 2005 - 8:33 PM -------------------- My car = 0-60 in ~9sec
It's slow, I know |
Apr 26, 2005 - 12:21 AM
Enthusiast ![]() Joined Mar 28, '05 From California Currently Offline Reputation: 0 (0%) |
UMm i got the JL audio 500/1 add in the manual it requires that if mounted, there should be at least an inch and a 3 quarters from the overhead view of the amp, and all around except the bottom, and i guess the amp shouldnt be in direct sunlight so thats all i can think of
Apr 26, 2005 - 1:20 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
I dont know, sounds like your running your amp and too low of a Ohm level, or its just a amp prone to overheat. You can do what I did with my jensen (POS amp but went threw hell and back) cross drill both of the sides of the amp that unscrew and mount like 4 CPU fans in there, after I did that it got warm but never hot, or kicked off again.
DTE -------------------- I am a thief.
do not buy anything from me. |
Apr 26, 2005 - 7:58 AM
Enthusiast ![]() ![]() Joined Apr 14, '05 From garfield hts. O-HI-O Currently Offline Reputation: 0 (0%) |
get some rubber washers from the hard ware store. or like rubber plugs or something that are about an inch thick, and put them between the box and the amp so there is like an inch gap between the amp and the sub box so air can flow under there. it will help alot!
Apr 26, 2005 - 8:43 AM
Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
get a new water cooled amp. i got water cooled subs in my living room
Apr 26, 2005 - 12:08 PM
i did like clipsetuner said. only i used those flashy ebay light up fans
Apr 26, 2005 - 4:43 PM
im not going to get a new amp cause i just got this in march but i might try to do the cpu fan thing
It's slow, I know |
Apr 26, 2005 - 4:53 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
chick , your amp might not be over heating.. it can be that your ground wire is getting to hot, thats a common problem where people think their amps are over heating... check your ground wire see if its melted. it may be too thin. and you might have to put it n a diffrent spot.
Apr 26, 2005 - 5:49 PM
even if you space it from the box it wont help that much because the circuit board would be on the top of the amp.
Ive got those fans that light up too, It just looked a little werid from my cross vents in the amp glowing different colors and humming. DTE -------------------- I am a thief.
Apr 27, 2005 - 1:06 AM
its not the ground i went through that prob already when i go and touch the amp itself with the back of my hand it burns to where i cant stand it. i am using 4 gauge wire i think. so i think that is enough and i can touch the + and - wires and they are normal temp. i went to mtx website and it said having the gain set up wrong could make it overheat. how exactly do you tune it. i think i got it pretty close to perfect but maybe not.
It's slow, I know |
Apr 27, 2005 - 9:55 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
Looky here
Apr 28, 2005 - 12:09 AM
i found out the problem with my amp after calling mtx they said its because the amp only supports single voice coil and my subs are dual bad buy job on my part.
It's slow, I know |
Apr 28, 2005 - 5:29 AM
I dont know about that, that seems bizzar. I have ran 2 RF HE2's off my Jensen 150watt rms and It did fine.
Apr 28, 2005 - 7:53 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
what, that does not make sence. unless you wire it up weird or something, you should wire it up so that the positive (+) or the amp goes to the positive input on one of the subs coils, then the negative of that goes to the positive on the other coil then that negative goes to the negative on the amp, i really dont think that you got a real anser, sounds like bs to me.
I use to have all 3 of my audiobahn 10s (single coil) each with a 600 watt (250 rms i think) and the amps where hidden (fully coverd and wedged together) in the wheel well under the trunk, they never overheated (probilby would aventualy but it never happend when I had em) so unless your amp is really cheap (witch mine where, mtx's are not the best but there not bad) overheating is just not gana happen like that withough a wireing problem. -------------------- ![]() |
Apr 28, 2005 - 9:21 AM
uhm, amps are sopposed to get hot.. what EXACTLY is the problem? does it cut off?
Apr 28, 2005 - 9:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
yea does it cut out, or go to protect mode.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 28, 2005 - 11:05 AM
that just sucks. i had a similar prob. i switched the subs to something alil more low power and it worked... u cant use that amp with the DVC 's.
Apr 28, 2005 - 5:27 PM
i have the subs hooked up + to amp and other + and - to amp and other - i got that from one of the diagrams in the manual.
It's slow, I know |
Apr 28, 2005 - 8:15 PM
Enthusiast ![]() Joined Feb 23, '05 From charlottesville, Va Currently Offline Reputation: 0 (0%) |
not trying to be mean but you get what you pay for.....I know MTX isnt the cheapest but its pretty low on the scale when you could have probably saved alot of money.......I bought 3 10" audiobahns allready in box brand spakin new off the show room floor for 150 and paid 100 for my amp........oh yeah.....did you get a decent wiring kit like streetwires or did you go to your local walmart?
Apr 28, 2005 - 8:17 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
check your ground
| Lo-Fi Version | Time is now: March 23rd, 2026 - 4:05 AM |
