> Amp Overheating, How can I keep it cool
post Apr 25, 2005 - 7:02 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
My amp was installed by myself $250 save at least. and I mounted it on top of my sub box its an MTX 801D monoblock with no fans mad.gif its powering 2 10" thunder 7500s and its in my trunk (hatchback). Even when i'm going down the freeway at 80 with the seats down it still overheats then 5 min later i can turn it on again for like 10 min. How can i keep it from overheating?
This post has been edited by chicklover345: Apr 25, 2005 - 8:33 PM
My car = 0-60 in ~9sec
It's slow, I know
- chicklover345   Amp Overheating   Apr 25, 2005 - 7:02 PM
- - pnoywitmustrdsauce   UMm i got the JL audio 500/1 add in the manual it ...   Apr 26, 2005 - 12:21 AM
- - Clipsetuner   I dont know, sounds like your running your amp and...   Apr 26, 2005 - 1:20 AM
- - rockstarbass1   get some rubber washers from the hard ware store. ...   Apr 26, 2005 - 7:58 AM
- - StreetRacing10PSI   get a new water cooled amp. i got water cooled sub...   Apr 26, 2005 - 8:43 AM
- - x_itchy_b_x   i did like clipsetuner said. only i used those fla...   Apr 26, 2005 - 12:08 PM
- - chicklover345   im not going to get a new amp cause i just got thi...   Apr 26, 2005 - 4:43 PM
- - SoundSlut_dotcom   chick , your amp might not be over heating.. it ca...   Apr 26, 2005 - 4:53 PM
- - Clipsetuner   even if you space it from the box it wont help tha...   Apr 26, 2005 - 5:49 PM
- - chicklover345   its not the ground i went through that prob alread...   Apr 27, 2005 - 1:06 AM
- - mikew04   Looky here   Apr 27, 2005 - 9:55 AM
- - chicklover345   i found out the problem with my amp after calling ...   Apr 28, 2005 - 12:09 AM
- - Clipsetuner   I dont know about that, that seems bizzar. I have ...   Apr 28, 2005 - 5:29 AM
- - creis   what, that does not make sence. unless you wire it...   Apr 28, 2005 - 7:53 AM
- - SoundSlut_dotcom   uhm, amps are sopposed to get hot.. what EXACTLY i...   Apr 28, 2005 - 9:21 AM
- - Drocay   yea does it cut out, or go to protect mode.   Apr 28, 2005 - 9:42 AM
- - SoundSlut_dotcom   that just sucks. i had a similar prob. i switched ...   Apr 28, 2005 - 11:05 AM
- - chicklover345   i have the subs hooked up + to amp and other + and...   Apr 28, 2005 - 5:27 PM
- - GTchic98   not trying to be mean but you get what you pay for...   Apr 28, 2005 - 8:15 PM
- - blkGT   check your ground   Apr 28, 2005 - 8:17 PM
- - chicklover345   i thought about audiobahns and my friend has had s...   Apr 29, 2005 - 6:49 PM
Lo-Fi Version Time is now: August 26th, 2026 - 8:23 PM
