Apr 27, 2005 - 6:32 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
i am only doing this because i got a new valve cover it is blue and i want to put it in. now i got the froplex or something from autozone it says it needs no sealent that it self seals. thats fine. well what size socket wrench will i need to do this?? i have a 7afe
Apr 27, 2005 - 8:16 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
how much did you spend on that, cause i need a new one mine is leaking oil.
and i thought it was 1/8th or something to open it. -------------------- hows it taste motha f*cka |
Apr 27, 2005 - 8:44 PM
Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
dont know the size try diff ones...u may not need to put that stuffo n the gasket...perfect seal aint an issue just make sure oil isnt leakin out
Apr 28, 2005 - 10:48 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
i did this a few weeks ago its not to bad execpt the new seals that go where the spark plug wires are the donut looking plugs
i worte this for some asking about paint the valve cover but talks about replacing that seal step 1 remove the 4 bolts and washiers in the cover step 2 remove the 2 bolts on the far left over the cam gear then remove that plastic plate thing step3 run a blade along the edge of the valve cover to break it loose then move the wire loom thats wraped in grey tape then left the valve cover off step 4 cover the cams with a plastic bag and stick a towel on top of that so nothing get in there step 5 use brake clean to get oil and other dust off the cover step 6 sand it and cover in a powder coat that can stand heat do 3 layers step 7 once dry spray your color on make sure it also can take heat spray one layer let dry and repeat until happy step 8 replace the seals put it back on tighten all the bolts and there you go This post has been edited by nik: Apr 28, 2005 - 10:55 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 28, 2005 - 11:45 AM
you should get a new gasket from toyota
Apr 28, 2005 - 11:59 AM
i payed $26 for new gasket it came with the main gasket ,4 donut rubber gaskets ,4 top bolt gaskets from napa
Apr 28, 2005 - 12:57 PM
im going to have toyota change my timing belt cause i dont have the time to do it my self. are they going to have to take off the valve cover in order to do this or can i replace my valve cover now and they wont touch it??
Apr 28, 2005 - 8:00 PM
i spent 33 on mine from advanced. and i didnt even replace those stupid donut things screw it plus anyways i got a new valve cover so i didnt care.
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:29 AM |
