> FS: Profec E-01 + greddy emange, just seeing who might be interested
post Apr 28, 2005 - 4:59 PM
nik
Joined Sep 30, '02
i was going to run this in my up coming 7agte but the more i talk with the shop the more i'm leaning toward running standalone
Greddy E-manage in perfect conditon only used for 6 months
Greddt profec E-01 eletric boost controller and tuning screen for e-manager only used 4 months this thing is awesome
the injector harness and timing harness are not included my friend has dibs on them if i sell my greddy stuff
i'm probably putting this on ebay
$650+shipping (price subject to change)
both are list for about 850- 900 on sites for both
ebay is about $470(profec) + 260 (manager)=$730 not shipped
but i include the usb cable to connect them $40 cable
so leave feed back if you would
PROFEC E-01
GReddy's new super multi-tasker is the PRofec e-01 designed as a combination boost-controller, data display / logger and e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to all the programming features provided with the latest e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
E-MANAGE - ENGINE CONTROL UNIT MANAGER
e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. For Honda VTEC cars you can adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1 programmer or our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information). There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications.)
post Apr 28, 2005 - 5:13 PM
nik
Joined Sep 30, '02
shipping at most probably $30 buck thats a guess
post Apr 28, 2005 - 11:07 PM
celicaboy04
Joined Sep 13, '04
From CA, USA
I am interested. I need to talk to Evil at EvilspeedTuning - He will be putting together a complete kit for my turbo 7afe (doing the downpipe and everything) so let me talk to him about adjusting it for the turbo set up - shoot me an email if you like Nik biggrin.gif.
This post has been edited by celicaboy04: Apr 28, 2005 - 11:08 PM
Armed? Armed with what?
Oh I dunno, colorful language, bad breath, a feather duster...Whatta you think theyre armed with guns you tit!
post May 1, 2005 - 8:31 PM
nik
Joined Sep 30, '02
still for sale
post May 3, 2005 - 9:09 AM
nik
Joined Sep 30, '02
now on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT
post May 5, 2005 - 12:25 PM
nik
Joined Sep 30, '02
2days 5 hours left
This post has been edited by nik: May 5, 2005 - 5:10 PM
post May 6, 2005 - 12:59 PM
nik
Joined Sep 30, '02
tomorrow it ends dont miss out on a good deal
post May 6, 2005 - 1:26 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
lol
To live, is to suffer
post May 6, 2005 - 2:03 PM
nik
Joined Sep 30, '02
QUOTE(bloodrain @ May 6, 2005 - 11:26 AM)
lol
[right][snapback]283590[/snapback][/right]
confused.gif what was that for?
post May 7, 2005 - 6:31 PM
nik
Joined Sep 30, '02
2 1/2 hours left
Lo-Fi Version Time is now: August 23rd, 2026 - 10:36 PM
