May 1, 2005 - 9:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
I've noticed that when I slow down sometimes that I hear this knocking coming from what I think is the back of my car. It only happens when I use the brakes. I think it started after I changed the brake pads. Is there a possibility that the pads are knocking for some reason? I checked them out and they seem to fit right. I jacked up the car and tried to find something loose under the back that would be knocking. I couldn't find anything. My trunk is completely empty and still does this, so it's not something in there. Any help or advice would be apreciated. Thanks.
Bigmeanbulldog55 Slowing down Knocking Noise May 1, 2005 - 9:50 PM
LewFX ive been hearing the same thing in my car but its ... May 1, 2005 - 11:19 PM
Blakout16 u must be making the car gnomes mad that live in y... May 1, 2005 - 11:31 PM
Bigmeanbulldog55 QUOTE(LewFX @ May 2, 2005 - 12:19 AM)ive been... May 2, 2005 - 12:20 AM
LewFX QUOTE(Bigmeanbulldog55 @ May 2, 2005 - 12:20 ... May 2, 2005 - 12:46 PM
CoSo QUOTE(Bigmeanbulldog55 @ May 2, 2005 - 2:50 A... May 2, 2005 - 2:59 AM
Bigmeanbulldog55 QUOTE(CoSo @ May 2, 2005 - 3:59 AM)QUOTE(Bigm... May 2, 2005 - 12:41 PM
Bigmeanbulldog55 Anyone else have any clues to what this might be? May 4, 2005 - 8:27 AM
mikew04 My dad had that problem with his car, and there wa... May 4, 2005 - 10:36 AM
slipgun if the tire isnt bolted on tight enough it can mak... May 4, 2005 - 4:16 PM
nik check the stud bolts if good
then have the rear br... May 4, 2005 - 4:59 PM
mark_426 Do you have springs or coilovers? I see you have a... May 4, 2005 - 9:02 PM
Bigmeanbulldog55 I've taken the rear wheel off several times. ... May 5, 2005 - 3:13 AM
LewFX if its your wheel bearing, jack up your back end a... May 5, 2005 - 9:09 AM
elvasoshexai i had the exact same problem with my camry after c... May 17, 2005 - 2:49 PM
TrdKing jack it up and if the wheel shakes side to side it... May 19, 2005 - 9:03 AM
LewFX thats pretty much what i said! May 19, 2005 - 9:05 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 11th, 2026 - 7:11 PM |
