May 5, 2005 - 2:57 AM
I was wondering if any of you who put in a push button starter used a relay or not. I know that with an actual S2000 button a relay is pretty much needed, but how about a button from Ignited ? one of these pictured
![]() relay or not ? -------------------- |
May 5, 2005 - 4:47 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
it depends on the switch.. we would need some specs to tell if you need a relay or not.
But be on the safe side. and use a relay. They are easy to hook up and cheap. So i dont see why you would risk melting a new switch. |
May 8, 2005 - 12:21 AM
Enthusiast ![]() Joined Apr 19, '05 Currently Offline Reputation: 0 (0%) |
How much do push button starters cost (purchase + install)? They seem pretty cool.
May 8, 2005 - 12:24 AM
I installed mine myself, took about an hour. I got my button on ebay for about $40 shipped
May 8, 2005 - 12:49 AM
QUOTE(Batman722 @ May 8, 2005 - 12:24 AM) I installed mine myself, took about an hour. I got my button on ebay for about $40 shipped [right][snapback]284180[/snapback][/right] Does it really thrust the car forward when starting in first gear? It says it may do that on Ignited's website. Does having the brake pedal depressed or the parking brake on help with that, or does it not happen on celis? |
May 8, 2005 - 12:57 AM
if you don't have the clutch in and try to start it, it will thrust forward like any car will. On an auto there is no problem. The button just replaces the last turn of the key basicly
May 8, 2005 - 2:22 AM
With the pushbutton starter there's no real reason to bypass the clutch start switch. And if you don't, like Batman says, it's just like turning the key to start when you push the botton. So you'd still need the clutch to be in.
And to answer your original question Batman, I would definitely use a relay. -------------------- New Toyota project coming soon...
May 8, 2005 - 2:27 AM
thanks Coomer. i was doing some research and I origionaly thought to use the relay for consistant 12V power, but now I see that some use it for consistantcy with the ignition wire. know what I mean ? Is that the best way ? opinions ?
May 8, 2005 - 3:06 AM
I don't know what you mean.
Say you connect terminal 87 to the starter wire. Are you asking where terminal 30 should connect to? If so, it can be either a switched ignition wire or a constant wire. -------------------- New Toyota project coming soon...
May 8, 2005 - 7:26 AM
all i did was wire my starter wire to the button then to a 12v power source why do you need a relay?
May 8, 2005 - 7:43 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
QUOTE(playr158 @ May 8, 2005 - 7:26 AM) all i did was wire my starter wire to the button then to a 12v power source why do you need a relay? [right][snapback]284223[/snapback][/right] You really don't. But I guess it's better safe then sorry. The factory ignition switch triggers a relay anyway so adding an additional relay is redundant. -------------------- ![]() Project ST204.5 99.88946% complete... |
May 8, 2005 - 11:31 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
Just swap the tranny and get an Automatic. J/K!
May 8, 2005 - 2:08 PM
^ should never be done
May 8, 2005 - 10:11 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
can someone make a how to on this subject cause i want to do it
May 8, 2005 - 11:21 PM
Enthusiast ![]() Joined Mar 14, '05 From san jose, california Currently Offline Reputation: 1 (100%) |
Push Button Installation
^S2000 Push button tutorial...I don't know...could be of some use to someone -------------------- 2000 Celica GT-S 6spd QUAIFE//TRD//AEM//FIDANZA//BEATRUSH//TRIAL//WINGSWEST//ALL JL AUDIO |
May 8, 2005 - 11:53 PM
for the S2K switch a relay is needed from what I have researched. I am probably going to wire in the realy like this
| Lo-Fi Version | Time is now: August 24th, 2026 - 9:45 PM |
