> Keyless Enty Power Trunk Help
post May 7, 2005 - 12:25 PM
Cutrara
Joined May 6, '05
From PA
I'm installing a keyless entry system in my Celica and it has an option for a power trunk release for my hatch. I know if you put in a power trunk solenoid, you need a dash switch to active it which renders the cable-pull on the floor useless.
My question is this: Can I install the power trunk solenoid so I can pop the hatch remotely but still use the cable-pull on the floor and skip the dash switch? I just like the cable-pull.
Replies (1 - 19)
post May 7, 2005 - 12:38 PM
yes. I have the same set up. Remote trunk popper and still able to use the lever.
there is a complete how to here, right click save as... with links to pics and everything needed
any questions, don't hesitate to ask
This post has been edited by Batman722: Aug 22, 2005 - 10:25 PM
post May 7, 2005 - 2:38 PM
Cutrara
Joined May 6, '05
From PA
Thanks a lot! This will be a big help.
post Dec 13, 2005 - 5:09 PM
djultimate
Joined Dec 1, '05
From South Windsor, CT
This how-to is MINT!!! Follow this thing and you'll be trunk poppin' in less than 2 hours! =o)
post Dec 13, 2005 - 10:16 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(djultimate @ Dec 13, 2005 - 2:09 PM) [snapback]366790[/snapback]
An excellent write up, helped me a ton. I pulled power from my antenna and kept blowing the 10 amp fuse. Put a 15 amp in and everything works fine now.
post Dec 13, 2005 - 10:35 PM
QUOTE(RocketScott @ Dec 13, 2005 - 10:16 PM) [snapback]366895[/snapback]
I'm happy to see you guys like my how-to smile.gif I haven't check it lately, do the links still work ?
Glad the slightly larger fuse solved the prob Scott.
I remember when I first installed it in my Celica, I would pop that hatch like 10 times a day biggrin.gif
post Dec 13, 2005 - 11:36 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(Batman722 @ Dec 13, 2005 - 7:35 PM) [snapback]366900[/snapback]
Yea, I almost go out looking for reasons to pop the trunk. I'd still like to run a dufferent power source back there so I can put the 10 amp fuse back in.
post Dec 14, 2005 - 12:47 AM
djultimate
Joined Dec 1, '05
I tapped into my hatch light's power source and put a 10 amp fuse on it. I got pics of the wire if you need it.
post Dec 14, 2005 - 7:27 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(djultimate @ Dec 13, 2005 - 9:47 PM) [snapback]366945[/snapback]
Isn't that switched so it's only on when the back is open?
post Dec 14, 2005 - 9:15 PM
djultimate
Joined Dec 1, '05
QUOTE(RocketScott @ Dec 14, 2005 - 7:27 PM) [snapback]367255[/snapback]
Yes, but a switch has two terminals and one of them has constant power and I used a wiring diagram to tell me which wire has constant power.
post Jan 17, 2009 - 7:34 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
I suggest we take an archive copy of the how-to just incase the other site chooses to remove or delete it.
post Jan 5, 2012 - 12:49 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
QUOTE (BloodyStupidDavey @ Jan 17, 2009 - 4:34 PM) *
It appears that this is just what has happened. Does anyone have a like to the original how to????
Thanks!
post Mar 23, 2012 - 9:15 PM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Hi Batman722, I have been watching the 6GC forums for a while before I bought my car, and I like your work wink.gif
I would like to make a remote boot (I'm Australian- no trunks for us tongue.gif) release, and it sounds like you how-to would be invaluable. However, the link is dead. Do you still have a copy on your computer that you could perhaps send or upload again?
Thank you,
post Apr 20, 2012 - 4:23 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
Bump for new link!
post Apr 27, 2012 - 6:44 PM
JoshuaM
Joined Mar 6, '12
Please, does anybody still have a copy of this document?
post May 18, 2012 - 7:04 PM
JoshuaM
Joined Mar 6, '12
Bumpety Bump Bump.... Anybody have a copy of this anywhere, even just in your downloads folder???
post May 19, 2012 - 11:24 PM
BillyM81
Joined Mar 15, '11
From Belfry, kentucky
Is this what you are looking for?
popper
post May 20, 2012 - 2:39 AM
JoshuaM
Joined Mar 6, '12
QUOTE (BillyM81 @ May 19, 2012 - 11:24 PM) *
popper
YES!!!
Thank you so much Billy! XD
post May 20, 2012 - 3:53 AM
smkr3w
Joined Nov 29, '10
popper
This post has been edited by smkr3w: May 20, 2012 - 3:54 AM
post May 20, 2012 - 6:41 AM
BillyM81
Joined Mar 15, '11
Oh your welcome. Sorry I did not post it sooner
Lo-Fi Version Time is now: September 19th, 2026 - 4:57 AM
