2 Pages V  < 1 2
Closed TopicStart new topic
> My celica vs...
post May 8, 2005 - 1:51 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
LOL... ok. This topic serves ZERO purpose and should be locked to prevent rampant stupidity.
post May 8, 2005 - 10:47 AM
agreed with kwanza lets lock this
but for stupidity sake
arizona haha you wish you could keep up with a GT they are significantly faster then a ST celica well the 00+ mustang gt's atleast
the model b4 is even slower so its not a bad race but will run you for your money
the V6 shouldn't be too much of a deal i think with a cold air and a full exhaust (from the block back i.e header, dp, ect.) you should be easily pulling on a v6 auto mustang
post May 8, 2005 - 10:53 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
ehh w/e let's lock this biotch lol
post May 8, 2005 - 1:26 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
get a new engine
post May 9, 2005 - 9:25 AM
darksecret
Joined Mar 9, '05
From Charlotte
In order to outrun a newer Mustang V6 you'll need to put out about 170-180hp and similar torque, Mustangs are boats but they do all right in a straight line. I have a modded GT and I can only beat the older V6's, newer it's a little bit different. In your case since you came for answers heres a few options:
7AFTE...best choice
4AGZE swap...second best
N/A mods:
CAI
full exhaust and header
shave about 100-150lbs.
port, polish, valve job
small shot (25) of nitrous
Those should be enough to keep up or beat a newer V6, if he ever gets a 2005 or newer you might as well go turbo.
post May 9, 2005 - 6:24 PM
dustin15brown
Joined Aug 17, '03
i wanna turbo bad... but to go 200whp.. what all would i need and what kinda prices
post May 9, 2005 - 6:43 PM
darksecret
Joined Mar 9, '05
From Charlotte
Each option is probably going to run you between $2-4 thousand based on the labor mostly. N/A would be the cheapest but you wont get 200 whp without nitrous on a stock (upgraded internals) 7A or a well built N/A motor with a lot of head work, a full head rebuild to your requirements is going to run about $1,500, that will also include port matching the throttle body, so that leaves you with intake manifold, exhaust, header, and intake. I think nitrous is your best bet, a rebuilt 7A with a forged bottom end, intake, full exhaust, and 75 shot of nitrous shouldn't have a problem pushing around 200whp or in that area, I have a knack for guessing drivetrain loss based on the set up and transmission and diff. used, but the Celica has this uncanny ability to make horsepower disappear. Oh yeah the nitrous set up is based on the parts, but you're still looking at around $2,000 w/o labor.
This post has been edited by darksecret: May 9, 2005 - 6:44 PM
post May 9, 2005 - 6:50 PM
Mike
Joined Oct 22, '02
From Toronto
QUOTE(Kwanza26 @ May 7, 2005 - 11:51 PM)
[right][snapback]284200[/snapback][/right]
hahahahahha!!!
post May 9, 2005 - 11:00 PM
94ST2
Joined Feb 7, '05
From Fresno, CA
Im gonna go down the nitrous route but I dont think you would be able to get quite as high as 200 whp. What performance mods besides the nitrous do you think would get close to that?
post May 10, 2005 - 9:43 AM
darksecret
Joined Mar 9, '05
From Charlotte
Intake, header, exhaust, and I would upgrade the ignition system. I wouldn't worry about buying expensive plugs, i've run different plugs on the Chevelle and I know a 150 shot of nitrous fouls out all of them pretty quick, I would buy some Autolite plugs they work and if you foul them you lose a whole buck and some change. Of course this is on a carburated car with a dry system so tuning is a little more difficult, but once you tune right get good plugs. Also getting the combustin chamber completely cleaned and polished will help a lot, one of the biggest problems with nitrous is the molecules accumlate in carbon composites that exist in the chamber and after enough accumulation they cause detonation, it's also never recommended to run nitrous if you have pistons with valve pockets due to the same results. The best kit for the Celica on the market will run around a thousand and you'll get a 75 shot max from it, but you can tune it to work exactly like boost. Nitrous is the best source of power, I personally feel it's better because you can get kits to give you more power for less money than any other power adder, but if you don't know what you're doing just like any power adder it will bite you. Also before some one comes here stating the obvious, yes you have to refill.
post May 10, 2005 - 10:56 AM
hahaha 150 shot nitrous on a 7afe
HAHAHAHAHAHAHAHAHAHAHAHAHAAHHAHAAHa
LOCK!
post May 10, 2005 - 11:25 AM
darksecret
Joined Mar 9, '05
From Charlotte
That was a 150 shot on a 427 big block not a 7AFE, damn playr read it. A 50 shot would be enough to foul a 7A without tuning.
This post has been edited by darksecret: May 11, 2005 - 9:14 AM
post May 11, 2005 - 1:58 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
Since 75 shot is max for the 7afe then even with good tuning I dont think you could reach 200 hp.
post May 11, 2005 - 9:09 AM
darksecret
Joined Mar 9, '05
From Charlotte
That's why I said around there and add a few other mods. It will take some work but it's attainable and by no means cheap. Think of this they have 110 flywheel hp, add a forged bottom end, that gets you an easily attainable 100 shot, add other mods bam there you go 200whp, at around $2,000-$3,000. It still comes out cheaper than a swap but it's just an option.
This post has been edited by darksecret: May 11, 2005 - 9:13 AM
post May 11, 2005 - 10:34 PM
dustin15brown
Joined Aug 17, '03
Hey ghost or a mod.. delete this plz.. it's gettin dumb
post May 12, 2005 - 1:26 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
Yeah I guess 200 is reasonable because you could just run a 100 shot with the venom system and just rely on it to do its job and stop the nitrous before detonation.
post May 12, 2005 - 1:30 AM
ghostdog
From ny to philly
I don't have the vaguest idea why you want this deleted .. but I'll do the next best thing. topic closed
2 Pages V  < 1 2
Lo-Fi Version Time is now: August 11th, 2026 - 8:42 PM
