May 8, 2005 - 12:36 AM
my xbox started to get a lot of dirty disk errors. any one else have this problem and found a fix that worked for them?
May 8, 2005 - 8:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
your going to probably need a new xbox or send it in. i had this problem, and it was a problem with like the drive or something. bought a new xbox because i got tred of it, and now its fine.
May 8, 2005 - 12:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
i had this problem with my ps2... so i took it apart and adjusted the laser that reads the discs....
-------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
You can buy a new drive for it and install it your self, but I wouldn't tear into that drive without knowing entirely what you are doing, if you 'clean' the lens in the wrong way (with a course cloth) you could scratch the lens and forever destroy your xbox drive. Then you will HAVE to buy a new one. Good luck though.
May 8, 2005 - 12:44 PM
i looked into this some more and it seems to be a common problem with original xboxes. im going to try adjusting the lense, if that dosnt work, the replacement thompson drive is about 30$.
May 8, 2005 - 1:08 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
Yeah I get the same thing and its freaking annoying.
May 8, 2005 - 1:25 PM
found some good info here
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 8, 2005 - 6:21 PM
i just clean out some of my old save games that were on the hard drive. seems to have really helped with the disk drive errors. so far i havent gotten one back yet.
i would also get errors when pausing dvds. so far those seem to be gone now too (crossing fingers). -------------------- 15PSI - 30MPG - Megasquirt Tuned
| Lo-Fi Version | Time is now: September 2nd, 2026 - 4:46 AM |
