May 10, 2005 - 10:07 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
Ok, after driving home from work last sunday, my car sat for a few days. later on last week I went out to start it, and it seemed as if the battery had died. I hooked the battery up to my friend's battery, and it still wouldn't start. The thing is, it seems like its closer to actually turning over when its hooked up to someone else's battery. Is this a starter problem? I need to fix this w/o paying someone else to do it, and I don't want to pay for a diagnostic. Is it a safe bet for me to just replace the starter?
Thank you for any help -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
jayi12-15psi Starter problems? May 10, 2005 - 10:07 AM
FAQdaWorld The engine turns over (as in the starter cranks?).... May 10, 2005 - 2:48 PM
jayi12-15psi yea, sorry, you're right. It was cranking, bu... May 10, 2005 - 4:07 PM
FAQdaWorld Check for some blown fuses, there prolly wasnt any... May 10, 2005 - 4:43 PM
jayi12-15psi yeah, I haven't done anything to the engine la... May 10, 2005 - 5:14 PM
FAQdaWorld Um, not sure exactly. Have you tried to see if you... May 10, 2005 - 7:43 PM
jayi12-15psi not sure what you mean by kick, it just sounds lik... May 10, 2005 - 8:26 PM
FAQdaWorld Pull the plugs and rest them against the head of t... May 10, 2005 - 9:04 PM
XxDJFate76xX take ur old starter to autozone they check it free... May 10, 2005 - 11:21 PM
jayi12-15psi It sounds the same with of without the wires to th... May 14, 2005 - 2:41 PM
jayi12-15psi checked for sparks, and then I noticed a broken fu... May 14, 2005 - 7:10 PM
jayi12-15psi does anyone know if the blown "alt 100" ... May 15, 2005 - 1:51 PM
FAQdaWorld Well, replace it and see what happens, no reason t... May 15, 2005 - 2:09 PM
CheesyLobster I bet thats the problem, something to do with your... May 15, 2005 - 3:46 PM
celicaboston1983 any updates im working on a car with problems simi... May 16, 2005 - 7:34 PM
FAQdaWorld If its not even cranking anymore than your starter... May 16, 2005 - 8:00 PM
jayi12-15psi it's cranking, I replaced the alt100 fuse, it ... May 17, 2005 - 1:26 AM
celicaboston1983 any updates May 18, 2005 - 3:11 PM
jayi12-15psi had it taken in, and after a $40 tow and ... May 19, 2005 - 11:48 AM
LewFX ouch that blows worse than a fuse May 19, 2005 - 11:58 AM
SoundSlut_dotcom i currently have the same problem but its my start... May 19, 2005 - 3:42 PM
celicaboston1983 so it was just a blown fuse I guess i should check... May 19, 2005 - 10:29 PM
FAQdaWorld Well, if it wont crank any more, either ur battery... May 20, 2005 - 12:25 AM
CheesyLobster and i bet it was the efi???? hehe, i blew my efi w... May 20, 2005 - 1:33 AM
SoundSlut_dotcom fixed it.. it was a loose wire.. May 20, 2005 - 10:09 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 15th, 2026 - 11:34 AM |
