> Whats the difference?, these 7afe pistons(link)
post May 10, 2005 - 3:58 PM
Nemises
Joined May 6, '04
From antioch CA
As some of you may know I am working on my 7afte. My question is I found these three auctions on ebay what is the difference between these 7afe pistons? What does the .020"/ .030" and .040" stand for? If I get the one with the biggest bore will lower my compression a little? Stock bore is like 81 I think the biggest one below is 82 is that enough to get a little more air and fuel into my cylinders? Does it even matter? I am getting a set im just curious.
Toyota Celica Corolla 7AFE pistons #P8059C +.020"
Toyota Celica Corolla 7AFE pistons #P8059C +.030"
Toyota Celica Corolla 7AFE pistons #P8059C +.040"
Replies (1 - 14)
post May 10, 2005 - 4:20 PM
you want to get the pistons with a 81mm bore
any larger and you have to bore your motor
to lower compression, you have to have a custom piston made or a thicker headgasket
so none of those will fit unless you bore the motor
This post has been edited by playr158: May 10, 2005 - 4:21 PM
post May 10, 2005 - 4:36 PM
Nemises
Joined May 6, '04
From antioch CA
QUOTE(playr158 @ May 10, 2005 - 9:20 PM)
[right][snapback]285197[/snapback][/right]
My fault I should have mentioned that. My car burns alot of oil so Im afraid its time for a little rebuild before the turbo. So yeah I am getting my block bored out. I know these are not low comp pistons or anything just stock. I am asking if I go with the biggest bore on one of these stock pistons can I lower my compression a little? Can i fit a tiny more boost?
Basically heres my question. I need new pistons and rings for my 7afe performance wise should i pick one of these pistons over the others (81.5 or 82) Or just get a set and get the thing bored out to match.
post May 10, 2005 - 4:45 PM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
My guess would you would prolly be able to take a bit LESS boost. Bigger displacement would mean you are getting more air and fuel burning with the same stock piston rods which is the big weakness with the 7a. So unless you were to get new rods You'd prolly be able to safely boost the same, if not less. But i doubt any more.
Compression should stay the same too.
-Ryan
AIM : FAQdaWorld
post May 10, 2005 - 5:00 PM
Nemises
Joined May 6, '04
From antioch CA
Thanks so basically I should get the 81.5? Or should I get the slightly bigger one 81.75 incase they have to bore out more to get all the scoring out the cylinders.
post May 11, 2005 - 5:17 PM
FallenHero
Joined Dec 26, '02
From Alabama
I wonder what new rods from toyota would cost... I wouldn't doubt it if they were a little better than my 1995 versions... if not simply because better materials or preparations.
post May 11, 2005 - 5:24 PM
you can get new ones online
http://www.importperformanceparts.net/
43$ a piece for new ones
you can also find piston/rod combo kits
or even a full rebuild kit
post May 12, 2005 - 10:05 AM
Nemises
Joined May 6, '04
From antioch CA
Well talked to the machine shope today they told me the would bore out my cylinders for $150. Thay told me just drop off the block and new pistons and come back in 2 days.
post May 12, 2005 - 11:03 AM
what shop was that nemisis?
and ask them how much they do head work for?
cause i think thats cheaper then shops down by me
post May 12, 2005 - 11:23 AM
Nemises
Joined May 6, '04
From antioch CA
It was Bouchers Auto Machine Shop Heres the link.
post May 13, 2005 - 2:23 PM
nik
Joined Sep 30, '02
this is the shop doing my head work boring etc
http://www.f2uning.com/pages/10/
only $100 to bore my block out
but $900 for all the head work and there was alot done to it
post May 13, 2005 - 2:51 PM
FallenHero
Joined Dec 26, '02
From Alabama
honestly, did they have to fab new valves or something, that's kinda harsh for head work.
post May 13, 2005 - 3:06 PM
nik
Joined Sep 30, '02
sorry wasnt clear
new valves
new springs
3 angle
stage 2 port and polish
cc the chamber
port match
new retainers
arp studs
insert nuts ( id have to show you a pic)
the coolent chambers cleaned
and few other things
i need to get a pic of it up
post May 14, 2005 - 12:31 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(FallenHero @ May 13, 2005 - 7:51 PM)
[right][snapback]286560[/snapback][/right]
Actually sounds kinda typical. Headwork is quite expensive especially when the head has to be disassembled and then re-assembled.
As for bores... anywhere from 80.00-150.00 is typical.
post May 15, 2005 - 9:37 PM
FallenHero
Joined Dec 26, '02
From Alabama
I thought he was talking about the machine work only, I didn't realize he was talking about new parts also. wink.gif
Lo-Fi Version Time is now: August 11th, 2026 - 5:54 PM
