May 14, 2005 - 9:37 PM
Enthusiast ![]() ![]() Joined Aug 7, '04 From US Currently Offline Reputation: 0 (0%) |
So I'm driving home and i stop at the light. The light turns green and i try to put the car in gear and it wont go. I turn the car off put it in gear and start the car and the engine bogs out and stalls. HELP PLEASE!!!!!!!!!!!!! What is the problem and how do i fix it.
This post has been edited by prpnum1: May 14, 2005 - 9:37 PM |
May 14, 2005 - 10:09 PM
BUMP
May 14, 2005 - 10:39 PM
someone please help me.
May 14, 2005 - 10:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Clutch is gone. Sounds like the slave cylinder blew out or something because of how sudden it happened.
-Doc This post has been edited by raven_101: May 14, 2005 - 10:42 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
May 15, 2005 - 12:06 AM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Did you check the fluids?
May 15, 2005 - 3:22 AM
Enthusiast ![]() Joined Feb 7, '05 From Fresno, CA Currently Offline Reputation: 0 (0%) |
Same thing happened to me when my clutch went out.
May 15, 2005 - 10:08 AM
well my clutch went out when i first had the car and it still went into gear the car just wouldnt move. Now it wont even go into gear.
May 15, 2005 - 12:40 PM
could be the slave cylinder like raven suggested
May 17, 2005 - 10:22 AM
If the slave cylinder was bad would it still move when you hit the clutch? mine does but i have no idea what else it could be.
May 21, 2005 - 3:52 AM
So you can see the slave cylinder moving when the clutch pedel is pushed in, but the clutch isn't working?
| Lo-Fi Version | Time is now: May 16th, 2026 - 12:01 PM |
