Apr 16, 2003 - 1:23 PM
Enthusiast ![]() Joined Mar 28, '03 Currently Offline Reputation: 0 (0%) |
What do you need to modify to shoot nitrious in your car? I have an ST so do I need to do anything to it before I buy a bottle and hook things up? And exactly when do you use nitrious, what RPM's? I might wanna try it out!
Apr 16, 2003 - 1:41 PM
Enthusiast Joined Sep 29, '02 From Norman Oklahoma Currently Offline Reputation: 0 (0%) |
depends on how big of a shot your gonna use, as to what modifications you need to do, also only use it at wide open throttle and above 3000 rpms. let me know exactly what your aiming for and i'll let you know how to do it.
Apr 16, 2003 - 4:24 PM
Enthusiast ![]() ![]() Joined Nov 11, '02 Currently Offline Reputation: 0 (0%) |
retard your timing
Apr 16, 2003 - 5:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 22, '03 Currently Offline Reputation: 0 (0%) |
I think that NOS is such a waste of money...Why get a SHOT of NOS that would last you like 5 seconds when you can turbo or do a swap and gain performance for as long as you have your car?? Just my opinion though...im not a big fan of NOS
-------------------- Note to new members. Discussions such as the ones below are forbidden.
http://www.6gc.net/forums/index.php?showtopic=26310&hl= |
Apr 16, 2003 - 6:45 PM
i also hate it when people (nobody in particular
Apr 16, 2003 - 7:19 PM
I think nitrous is one of the cheapest horse power mods you can get. It may only last a couple of seconds, but thats all it takes to kick someones ass!!! Plus the fact that it is only used for a couple of seconds means that it won't kill the motor as fast. Nitrous is a good mod, especially if you dont have the money for a turbo setup, and it looks really f*cking cool when you purge. I say go for it.
Apr 16, 2003 - 7:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
one time I was using NOS and it blew the welds on my intake manifold
then the floorpan fell out... haha |
Apr 16, 2003 - 8:24 PM
![]() Enthusiast ![]() Joined Apr 11, '03 From Australia, Newcastle Currently Offline Reputation: 0 (0%) |
Sounds like a movie to me. Fast N Furious did it.
Apr 16, 2003 - 10:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
HA, Why did the floorpans fall off anyway, and what was spitting out those green bolts? : )
ANYWAY, N2O is great for the money. On an engine like ours it can last up to 15 seconds on one shot. (running it at low RPM's is REALLY bad though.) |
Apr 16, 2003 - 10:42 PM
![]() Enthusiast ![]() ![]() Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
I think the easiest nitrous upgrades you can do is the Zex dry nitrous system. You can buy a Zex cone filter to put on an intake and it has a place to put the nitrous injecter so you dont have to drill a hole in your intake tube. It injects the nitrous into the intake so you don't need to do half as much installation with selenoids etc... Just install the nozzle with or without the Zex air filter (it just makes it easier with that) install the bottle, install the computer unit, run some wires and install arming switch. The nitrous is administered when the system is armed and your at wide open throttle so you can screw up the timing you should shoot.
takes like 3 hours sor so, and cost a lil over $500, up to 75 shot depending on injector but if you run that much you should retard your timing This post has been edited by Milds3vn: Apr 16, 2003 - 10:43 PM |
Apr 16, 2003 - 11:53 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Where didd u get the Zex kit and the filter for only 500 bucks?!?!?!
-------------------- 95 Toyota Celica GT
Apr 17, 2003 - 12:13 AM
im just looking at a normal 45 shot. whats needed to be done? |
Apr 17, 2003 - 12:38 AM
![]() Enthusiast ![]() ![]() Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
The most popular and safer kit for our cars is the Zex dry kit. I think they only have 55, 65, and 75 shot jets, but you can probably run either one fairly safely, without doing serious long-term damage to your car. Damage to your vehicle while running nitrious is all on the driver... All you need for the install, a drill, screwdrivers, wire cutters/strippers, and cooler spark plugs. Running low shots, you can probably get away with not retarding the timing... but I can't say for sure. I've ran up to a 75 shot, with little problems. I only sprayed while racing, and it was always in mid 3000rpm, in either 2nd or 3rd gear. 2nd isn't very safe... but you can. |
Apr 17, 2003 - 6:19 AM
Enthusiast ![]() Joined Feb 18, '03 From UK Currently Offline Reputation: 0 (0%) |
How do you retard your timing ? And what does this mean?
Apr 17, 2003 - 9:19 AM
2nd that! |
Apr 17, 2003 - 11:00 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
When using a shot of nitrous, what happens when you shift gears?
With most setups there is a WOT switch that only allows you to use nitrous when your at Wide Open Throttle. so when you shift gears and let off the gas does the nitrous shut off untill you floor it again? -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Apr 17, 2003 - 5:10 PM
![]() Enthusiast ![]() Joined Dec 1, '02 From minneapolis Currently Offline Reputation: 0 (0%) |
the nitrous will go when you are pushing the button
so when you shift, just lift off the button |
Apr 17, 2003 - 5:47 PM
Just get a zex kit, they are the easiest to use and install. All you have to do is drive the car, and the nitrous takes care of itself.
Apr 17, 2003 - 8:42 PM
so does the zex kit have like a button you push when you wanna use it or does it just come in whenever??
Apr 17, 2003 - 11:16 PM
On the older 94-95 Celica's... retarding the timing is done simply by turning the distributor a certian number of negative degress. Of course, use a timing light and make sure you have your adjustments done correctly. On the newer OBD-II 96-99 Celica's, adjusting the timing is done with an OBD tool (little computer gizmo)... Retarding the timing means, basically, retards the ignition of the spark plug to fire slighty after TDC (top dead center, when the piston fully compresses the air/fuel misture). As far as Nitrious engaging between shifts, when the throttle isn't wide open, I think it retards and delays until the throttle is wide open again before engaging. Like I mentioned before, try not to spray in 2nd, unless you know what you're doing. Spraying in 3rd gear is safer because unless you're gonna run 13's or 14's... you probably won't shift past 3rd in a 1/4 mile drag...=] |
| Lo-Fi Version | Time is now: August 24th, 2026 - 7:09 PM |
