> leaking oil, plz help
post May 25, 2005 - 3:18 PM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
Ok guys..im starting leaking oil by the "sensor-like" pictured in the picture (sorry the red arrow isnt large)...can you guys tell me what part is that (part code if you can). The leaking is between that black part and the engine. Can you also tell me if that is expensive to repair. TIA
Replies (1 - 9)
post May 25, 2005 - 3:22 PM
its a cheap thing to fix. that kind of looks like your oil pressure sender. unscrew it out and see if there is some type of a gasket there, or if the sensor is just starting to come loose.
post May 25, 2005 - 3:40 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
thats a fancy lil setup there
post May 25, 2005 - 4:21 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
What header and insulation is that?
And lagos pretty much covered it.
post May 25, 2005 - 4:34 PM
thats your oil pressure sender, just unscrew it, and wrap thread tape around it (2 times) and reinstall. wink.gif
post May 25, 2005 - 5:16 PM
HaRv3sTeR
Joined Nov 22, '03
QUOTE(presure2 @ May 25, 2005 - 9:34 PM)
[right][snapback]291760[/snapback][/right]
thread tape???
post May 25, 2005 - 6:07 PM
HaRv3sTeR
Joined Nov 22, '03
the part that is leaking is this one (but this is from a ST engine)
the leak is where the arrow points (between the two different materials)...i was wrong in the first post because it isnt between the black plastic cover and the sensor
is that the oil pressure sender?
This post has been edited by HaRv3sTeR: May 25, 2005 - 7:07 PM
post May 25, 2005 - 7:21 PM
yea, its the pressure sender, if its leaking from in between the plastic and metal, i dont think you'll be able to fix it.
thread tape you can get at any hardware store, its a special kind of tape you use on the threads to seal them from leaking. wink.gif
post May 25, 2005 - 7:38 PM
HaRv3sTeR
Joined Nov 22, '03
post May 26, 2005 - 11:07 AM
HaRv3sTeR
Joined Nov 22, '03
new sender in...no more leaking...thx guys
Lo-Fi Version Time is now: August 27th, 2026 - 7:10 PM
