May 27, 2005 - 1:24 PM
Enthusiast ![]() Joined Jul 16, '03 From Boise, Idaho Currently Offline Reputation: 0 (0%) |
it started with every once in a while now it is everytime i turn in two days. i looked at the power steer pump and it looks like there is a lot of grease down there. so my guess is that the pump went out or the piping came off or something. i cant back out of a parking spot w/o my car clicking and almost if not stalling. i saw that what looks like the pump is really far down, how hard is it to change and what has to be done to get to it? or should i just take it to a mechanic and save all the hassle, whats the price difference b/t me doing it and a mechanic doing it?
This post has been edited by chicklover345: May 28, 2005 - 10:15 PM -------------------- My car = 0-60 in ~9sec
It's slow, I know |
chicklover345 short??? May 27, 2005 - 1:24 PM
lagos check you power steering fluid. if its full, then ... May 27, 2005 - 1:58 PM
chicklover345 i replaced the axles about 1,000 miles ago and the... May 27, 2005 - 2:04 PM
Hanyo do you have to fill up the powersteering pump flui... May 27, 2005 - 4:14 PM
chicklover345 i've had the car for over a year now and have ... May 27, 2005 - 4:17 PM
chicklover345 now i know that the click is the starter trying to... May 27, 2005 - 6:02 PM
chicklover345 QUOTE(chicklover345 @ May 27, 2005 - 4:02 PM)... May 29, 2005 - 5:32 PM
DamDirtyApes i had that changed
my problems were that the car ... May 27, 2005 - 6:07 PM
chicklover345 mine only stalls when i'm turning, its like it... May 27, 2005 - 6:20 PM
Hanyo the fastest and easiest way to tell if its your po... May 27, 2005 - 7:53 PM
chicklover345 ill try that May 27, 2005 - 9:33 PM
chicklover345 i forgot to ask, how you take off the power steeri... May 27, 2005 - 9:37 PM
lagos get under the car, loosen the tension bolt on it..... May 27, 2005 - 11:35 PM
chicklover345 ok i tried that and it still does it. when i turn ... May 28, 2005 - 10:18 PM
lagos you hear your starter kick in when you turn the wh... May 29, 2005 - 2:00 AM
K-ESD if the problem only came in after you put in the a... May 29, 2005 - 10:09 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 9:17 AM |
