> 7afte questions
post May 31, 2005 - 4:17 PM
CelicaST18
Joined Sep 1, '04
From Ohio
So i followed NIK's How-to on the 7afte. Got everything all hooked up and took it for a spin. I was makin about 6.8psi and it was fast. Until i got to about 4000 RPS, at which point it felt like it was bogging down. Oh, and there was a lot of smoke. Does anyone know what could be wrong?? I have sat here for hours thinking on it. If you have ANY input at all, please, input it.
- CelicaST18   7afte questions   May 31, 2005 - 4:17 PM
- - nik   did you prime the oil through the turbo before run...   May 31, 2005 - 4:20 PM
- - nik   you have a 96 so you have the obd 2 so you didnt r...   May 31, 2005 - 4:30 PM
- - CelicaST18   i have a used (46,000 mi) ct26 single entry turbo,...   May 31, 2005 - 4:34 PM
|- - nik   QUOTE(CelicaST18 @ May 31, 2005 - 2:34 PM)i h...   May 31, 2005 - 4:43 PM
|- - edo17982   QUOTE(nik @ May 31, 2005 - 11:43 PM)QUOTE(Cel...   May 31, 2005 - 4:46 PM
- - CelicaST18   i don't have any way to adjust the fuel...the ...   May 31, 2005 - 4:44 PM
- - CelicaST18   i'm going to go check my intercooler pipes for...   May 31, 2005 - 5:04 PM
- - nik   oops your right ok so oil pull off the IC ...   May 31, 2005 - 5:12 PM
- - Hanyo   what is the size of your feed and return lines on ...   May 31, 2005 - 5:14 PM
|- - nik   QUOTE(Hanyo @ May 31, 2005 - 3:14 PM)what is ...   May 31, 2005 - 5:16 PM
- - CelicaST18   no oil in the i/c pipes...is it possible for a sea...   May 31, 2005 - 5:17 PM
- - CelicaST18   did you use pcv valves for the check valve?? do yo...   May 31, 2005 - 5:18 PM
|- - nik   QUOTE(CelicaST18 @ May 31, 2005 - 3:18 PM)did...   May 31, 2005 - 5:26 PM
- - FallenHero   I was thinking the same. oil drain. also, where ...   May 31, 2005 - 5:25 PM
- - nik   with me ,edo,fallen ,and hanyo on it well get it f...   May 31, 2005 - 5:27 PM
- - CelicaST18   the oil drain line is the same size as the factory...   May 31, 2005 - 5:30 PM
- - FallenHero   so does it smoke all the time or just at 4k+?   May 31, 2005 - 5:32 PM
- - CelicaST18   I fixed the bogging when boost came on, the check ...   Jun 1, 2005 - 11:25 PM
Lo-Fi Version Time is now: August 25th, 2026 - 2:07 PM
