> FULL MAJOR TUNE UP, what am i missing??
post Jun 8, 2005 - 10:20 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
spark plugs, wires, cap and rotor
flush coolant and power steering fluid, transmission oil change
timing belt and tensioner
replace fuel filter, pcv valve, valve cover gasket
do i need to replace the fuel injectors??
how bout the water pump??
thanx
alex
post Jun 8, 2005 - 10:32 PM
do the water pump and gasket if you do the timing blet. also a new thermostat .
fuel injectors normally dont go bad when they are still in a running car, but you can mail them out to a few places that will clean and balance them for you if you are really worried.
This post has been edited by lagos: Jun 8, 2005 - 10:33 PM
post Jun 9, 2005 - 12:01 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
this is gonna be my first major tune up...original belt since i got the car at 29K and now its at 117K...i've searched on this forums and some people have done it 3 times within 100,000 miles...guess it really depends on how hard u push ur car...
which gasket?? the head gasket??
just makin' sure...
post Jun 9, 2005 - 12:03 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Brake fluid flush while you're at it, fuel injector service.
Valve cover gasket isn't necessary at 100,000 miles, though you can. Clean the intake.
post Jun 9, 2005 - 12:08 AM
not head gasket, i meant a new gasket for the new water pump. you can do your valve cover gasket if you think its leaking oil.
Lo-Fi Version Time is now: September 1st, 2026 - 1:25 AM
