Jun 14, 2005 - 1:35 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '04 From San Diego Currently Offline Reputation: 0 (0%) |
When I brake at high speed my steering wheel shakes and brake pedal shakes.
I checked for warped rotors and they were well within spec. I'm going to see if my tires need rebalancing. I heard it could also be worn wheel bearings, though I'd think that wouldn't be just a braking problem. Anything else I should check? tia. -------------------- ![]() |
mr_dude Possible Problems Jun 14, 2005 - 1:35 PM
celicaboston1983 isnt the pedal suppose to shake if you have abs? Jun 14, 2005 - 1:44 PM
Blakout16 abs only goes active when u stomp on the f'er ... Jun 14, 2005 - 1:47 PM
playr158 speed doesn't trigger abs my friend
you can g... Jun 14, 2005 - 1:50 PM
Newbie check the balance of the tires.. Although, I'm... Jun 14, 2005 - 3:37 PM
mr_dude QUOTE(mr_dude @ Jun 14, 2005 - 10:35 AM)I che... Jun 14, 2005 - 11:14 PM
MonsterBOX could be a frozen caliper i had one and didnt know... Jun 14, 2005 - 11:56 PM
LewFX you sure nothing is bent? a rod, arm, axle, belt, ... Jun 15, 2005 - 12:02 AM
mr_dude Monster - good suggestion, I wonder if it is a cal... Jun 15, 2005 - 12:30 AM
Galcobar Could be simpler -- alignment problem. But the fac... Jun 15, 2005 - 1:32 AM
GT4WRC My money is on the rotors if the issue is from hig... Jun 15, 2005 - 2:10 AM
mr_dude QUOTE(GT4WRC @ Jun 14, 2005 - 11:10 PM)When y... Jun 15, 2005 - 12:58 PM
macavely when braking hard its is normal to have ur wheel a... Jun 15, 2005 - 7:22 PM
mr_dude QUOTE when braking hard its is normal to have ur w... Jun 15, 2005 - 10:41 PM
gtcelica94 get the tires balanced . thats what it is. my car ... Jun 15, 2005 - 10:58 PM
GT4WRC Very cheap and simple way to eliminate wheel / tyr... Jun 16, 2005 - 3:54 AM
mr_dude I'll do that, thanks. Just gotta dig the whee... Jun 16, 2005 - 11:49 AM
MonsterBOX well i had stock rims and had them balanced like 3... Jun 19, 2005 - 11:59 PM
GT4WRC QUOTE(MonsterBOX @ Jun 19, 2005 - 11:59 PM)we... Jun 20, 2005 - 4:10 PM
Galcobar When re-balancing the tires on the wheels, did you... Jun 20, 2005 - 5:51 AM
MonsterBOX not necessarily..only if you need to you can Jun 20, 2005 - 9:10 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:50 AM |
