Jun 23, 2005 - 10:43 PM
Enthusiast ![]() Joined May 20, '05 From San Diego, California Currently Offline Reputation: 0 (0%) |
I bought my Celica a while ago with stock (I think) Toyo tires on 15s. What should my PSI be? I think I might have been a little too eager and pumped it all the way to 38~40 PSI for the front.
Jun 23, 2005 - 11:48 PM
every tire has the correct psi. most common tires are 35psi i think, my performance tires need 51. so check your tire. its the writing on the sidewall.
Jun 24, 2005 - 1:27 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
51 is really high... i run 34 with my "performance" tires
Jun 24, 2005 - 2:45 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
The tire does NOT show the correct PSI, it shows the maximum it can run.
Each car has a different correct PSI, even if they are using the same tires. The correct PSI is written on a label inside your glove box. |
Jun 24, 2005 - 3:03 AM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
I run 35 in front and 34 at the back. Seems to be fine... and lewfx you might want to reduce your psi?
Jun 24, 2005 - 3:08 AM
QUOTE(LewFX @ Jun 23, 2005 - 11:48 PM) every tire has the correct psi. most common tires are 35psi i think, my performance tires need 51. so check your tire. its the writing on the sidewall. [right][snapback]304038[/snapback][/right] wow dude you tires are going to pop.. your reading the max tire pressure.. mores cars are 28-35 psi .... and remeber that are your tires get hot the air pressure goes up ... i think are clies are 32 psi .. -------------------- |
Jun 24, 2005 - 7:47 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
i dunno if this helps but from another forum:
this was given to me by CamryMan.org user "cdssolara" and it is the best formula for tire pressure that I have read. Take your vehicle weight plus driver and divide by 100, this is your base. Add 2psi to that if you have a OE suspension. Add 2 more psi on the heavy end of your car (front for our cars) So you say that you car weighs 3400lbs that means 34lbs is the base, so for a Camry with stock springs 38 front 36 rear, with a performance springs it is 36 front and 34 rear ... Play with it from there to suit your taste. more pressure for performance driving and less for driving grandma to the store. btw.. anyone know how accurate those tire pressure checkers are? you know.. those stick ones you can get at a dollar store or something where this thing pops out to show you the psi -------------------- |
Jun 24, 2005 - 7:58 AM
just spend 5 bucks on a digital one...
Jun 24, 2005 - 9:03 AM
specs say 1,356 @ 51 psi
Jun 24, 2005 - 9:52 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
recomended air pressure is between 32psi or 35 psi.
Jun 24, 2005 - 11:07 AM
ok ok, i got em at 35psi.
Jun 24, 2005 - 3:36 PM
Enthusiast ![]() ![]() Joined Nov 17, '03 From New York Currently Offline Reputation: 1 (100%) |
QUOTE(Galcobar @ Jun 24, 2005 - 7:45 AM) The tire does NOT show the correct PSI, it shows the maximum it can run. Each car has a different correct PSI, even if they are using the same tires. The correct PSI is written on a label inside your glove box. [right][snapback]304116[/snapback][/right] Yea this is correct, that is the MAX! You can also find the correct tire pressure for your car on the inside of your door jam, like where the color code and stuff is, give it a check. I believe our celica are suppose to be run at 33PSI. Also for better handling you want it a little low, more tire touches the ground and grips better (most people run lower tire pressure at the track, more tires grips and they get off the line better). Also if you are lowered at all, then lower tire pressure allows the tire to take some of the impact when you hit bumps and stuff because it had a lil flex, instead of JUST your suspension. |
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:30 AM |
