Jun 23, 2005 - 11:34 PM
Enthusiast ![]() ![]() ![]() Joined Nov 24, '04 From Moscow, russia Currently Offline Reputation: 0 (0%) |
ok guy's it's the retarded GT 4 owner again from across the waves
any ideas what happened, by boost seems to be all screwed up if i floor the gas, an go up through the gears the car goes but doesn't kick like it used to i don't think, and boost gauge only hits 0.3kg...... if i'm lazy(i don't do this alot) and put my foot down in a high gear (say 4th only going at 50kph) the boost starts to kick in and and i can show as much as 0.7kg on the gauge.... is this normal, 0.3kg seem real low! what have i broken ???? any ideas would be a great help, thanks Pete the popstar -------------------- ![]() Life is for living, and you don't get a second chance Take care now !! |
popstar strange boost readings Jun 23, 2005 - 11:34 PM
lagos well the good news is that you didnt break anythin... Jun 24, 2005 - 10:17 AM
nik .3 kgf= 4.267 psi
.7 kgf=9.956 psi
1.0 kgf= 14.223... Jun 24, 2005 - 10:29 AM
Mr_E Might be in limp mode. Pull the engine codes and s... Jun 24, 2005 - 1:26 PM
mark_426 Where did you install your boost gauge? If you tak... Jun 25, 2005 - 6:03 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 6:24 PM |
