Apr 21, 2003 - 2:51 PM
So you actually have the engine in your car and running now? It sounds like it from your profile and sig.
Anyway, I think that all of the 4A-GZE engines had the air blowoff valve, but I'm not sure on that. -------------------- New Toyota project coming soon...
Apr 21, 2003 - 11:20 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
Wow. The Gze pulls 14psi with an upgraded pulley?
Apr 21, 2003 - 11:26 PM
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
you don't want cams higher than 256 on the 4agze... higher than that and the idle will be awful... i mean like, rough, unpleasant, you name it. TRD cams aren't available any more, but you could get HKS, Toda, or others. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
May 3, 2003 - 6:52 PM
Enthusiast Joined Sep 29, '02 From Norman Oklahoma Currently Offline Reputation: 0 (0%) |
With the 4agze and the transmission out of a front clip corolla, will the trans bolt right in place of the old 7afe one , or does it need custom axles? Also will the wiring harness be somewhat similar to the celicas? If i buy a front 4agze clip out of a front wheel drive corolla, what things will i need that wouldnt come with the clip?
May 3, 2003 - 7:46 PM
the axles in the clip should work, if they don't, your ST ones should be fine. the tranny will bolt right up. it will be better, because it was designed to work with the 4agze. wiring, well, it will be about the same level of complexity as putting a 3sgte in a GT. if you get a clip, you should have everything you need. and in japan, it's not a corolla, it's a levin. -------------------- 1994 Lexus ES300
May 4, 2003 - 11:50 PM
It makes you wanna shed a tear. |
| Lo-Fi Version | Time is now: August 31st, 2026 - 12:13 AM |
