Jun 25, 2005 - 9:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
okay, i installed my curren tails long ago. but i keep burning out the fuses for the turn signals and the red lights when the low beams are on. i keep having to replace them over and over and over. anyway, i think plyr was the one that told me i probably pinched some wires or whatnot. so i try to take off the tails but.,.. i tightened the bolts too much when i first put on the tails and they wont come off! the bolts are stuck. i think i messed up the thread. is there any way to take these bolts off or do i have to saw them off or something?
Jun 25, 2005 - 9:57 PM
wow.... settle down hurcules..... i dont know of anything other than sawing right off hand..... try a wrench or vice grip to un-do it
Jun 26, 2005 - 1:37 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
did u try some PB-Blaster or wd-40 on them ? I use PB blaster on everything lol
-------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Jun 26, 2005 - 2:20 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
I have the same problem. had my curren tails on for about a year and now I can't get the bolts off. when I turn the bolt the whole thing turns. tried pb blaster, tried using a grip wrench to hold the screw but to no avail .. damnit
Jun 26, 2005 - 2:40 PM
i had that same problem when i had my coupe... what happened with me was where the stude is connecter to the light broke off.. so i unscrewwer the other 2 nuts and then pulled the light off ... you have to pull hard but it comers off... and next time you take your lights off .. tigight then with just your hand that good enuff to hold them ..
| Lo-Fi Version | Time is now: August 23rd, 2026 - 3:46 AM |
