> BUMPs ON MY HOOD, battery hitting my hood
post Jul 3, 2005 - 1:49 AM
tranxendz
Joined May 2, '03
From San Diego
I changed the battery in my car. It was so hard to put the clasp back onto it..Finally I got it on and I didn't raelize that it wasn't sitting all the way down like it should and I slammed my hood on top of the top metal piece that holds down the battery. And now i have 3 bumps on my hood and I'm so upset. Has anyone had these type of issues? How can I fix it? I'm usually anal about my car having dents or bumps...And that one is just annoying me.
HELP!
Replies (1 - 2)
post Jul 3, 2005 - 2:44 AM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Sounds like a good reason to get a new hood! If not try a body shop (probably more than new hood).
post Jul 3, 2005 - 9:58 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Had a similar problem.
I failed inspection because my battery wasn't secured. Had to get a universal clamp system, and the J-bolts were too long, and pushed up through, as you said.
Either cut or file or grind them down, unless its actually battery terminals hitting.
As far as fixing it, it'd probably be cheap at a body shop, just pop em out. Go get some quotes.
Lo-Fi Version Time is now: May 18th, 2026 - 7:45 AM
