> 3sgte vs 5sfte exhaust path, Who knows?
post Jul 6, 2005 - 2:10 AM
urbandork
Joined Jul 16, '04
From Los Angeles
Currently im looking for exhaust for my 5sfte when its done. Ill have a stock 3sgte twin entry ct26 with stock manifold and DP.
My question is with the 3sgte turbo parts on my 5sfe block, will the exhaust path be the same as a 3sgte alltrac?
The reason why i ask is because i have found an aftermarket mid pipe for a 3sgte st205/st185. I want to know if i can mount the mid pipe on my GT with no problem. Im not sure how similar the underside of the my GT is compaired to an st205 celica, and even IF the same WILL the exhaust on my 5s block w/ 3s turbo parts be about the same place as it would be on an alltrac with a 3s block and turbo parts?
Things to keep in mind are the pitch/angle at which the header attatches to the block between a 5s and a 3s when mounted in a GT and gt4 respecitivly. Will 3s parts lay the same way on a 5s as it would in on a 3s? Whats the diffrence in clearance of the oil pan and other things near the lower end of the block?
This post has been edited by urbandork: Jul 6, 2005 - 2:14 AM
- urbandork   3sgte vs 5sfte exhaust path   Jul 6, 2005 - 2:10 AM
- - presure2   the mid pipe wont work.   Jul 6, 2005 - 5:38 AM
- - urbandork   from the answer man himself lol. thanks   Jul 6, 2005 - 1:03 PM
- - Consynx   Pressure, how similar is the 5th gen exhaust to th...   Jul 6, 2005 - 1:08 PM
Lo-Fi Version Time is now: May 7th, 2026 - 1:37 AM
