Jul 9, 2005 - 1:54 PM
Well, I received my projectors and clear high beams Friday along with most of my other GT4 front facia parts. I was stunned at how nice they look in person.
I didn't realize the clear high beams do not come with bulbs. Do the stock bulbs work? Are there other options? I did some searching and I am new to the terminology. What is H.I.D? One thing I know is that I want clear bulbs. Also, how important is it to do the projector LHD modification? When I looked at the how-to and Doggy's thread about it, I am not sure I could tell a difference between the before and after pictures. What else do I need to get these beautfiful pieces operational? I read I need a wiring harness for the projectors. Are there bulb options for the projectors too? Anything else? Thanks folks. I love this forum. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jul 9, 2005 - 2:04 PM
Enthusiast ![]() Joined May 25, '05 From Reno Currently Offline Reputation: 0 (0%) |
from what i've heard in the past the highs use the same bulb as before. i've also heard that if u don't do the mod your going to be blinding people comin up to you cuz the projectors are brighter..
This post has been edited by d-roCk: Jul 9, 2005 - 2:04 PM -------------------- ![]() |
Jul 9, 2005 - 2:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
stock high bulbs work, or if u want u can get different ones.
PIAA, Streetglow, Eurolite, Silverstar...whatever. H.I.D. is about $300-$400 for a kit. Longer lasting bulbs, brighter bulbs. If u r out at night and see the newer luxury cars with the bright azz blue or purple lights, thats H.I.D. i didn't know there was a how-to to mod it from RHD to LHD. Mine r fine right outta the box. for the wireing harness i used an H4 female connector and just popped out the top connector. Bout $4 at autozone for the pair. U can get any H1 bulb for the Low projector. Im running streetglows and they put out a nice white light. This post has been edited by Phat_99CeliGT: Jul 9, 2005 - 2:19 PM -------------------- Jared Harwell
Jul 9, 2005 - 2:20 PM
Enthusiast ![]() ![]() ![]() Joined Nov 20, '04 From Carlisle, PA Currently Offline Reputation: 27 (100%) |
Sent you a PM about HIDs.
Jul 9, 2005 - 2:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Well it is a major difference the shot of the lights modified or not. Believe me. I made the shots
The lights are made for RHD cars. So the beam is cut off in the wrong place. The should be cut off in the Left instead of the right. So now you will blind other drivers and that can be dangerous and can cause accidents. If you need any other help regarding the conversion PM me. This post has been edited by Kadett: Jul 9, 2005 - 2:39 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 9, 2005 - 3:17 PM
QUOTE(Phat_99CeliGT @ Jul 9, 2005 - 2:18 PM) U can get any H1 bulb for the Low projector. [right][snapback]310451[/snapback][/right] Thanks for the replies guys. I am at work right now or I would just look. After briefly looking at the lows last night, I thought they came with bulbs. Is this not the case? -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jul 9, 2005 - 3:25 PM
Yes the bulbs come with the lamps.
Jul 9, 2005 - 3:29 PM
u guys got bulbs?
i didn't. i got the 2 prong connector that the bulb plugs into. -------------------- Jared Harwell
Jul 9, 2005 - 3:34 PM
Ow. Well my contact was very good. He also delivered the complete wiring harness + bulbs for my JDM Tail lights. Instead of another dutch toyota parts dealer from which Fietsbel had his JDM tails from.
So maybe i am just lucky with the parts dealer. But the first thing i did was replacing the standard bulb with a Philips Blue Vision bulb! This post has been edited by Kadett: Jul 9, 2005 - 3:40 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 9, 2005 - 3:48 PM
QUOTE(Phat_99CeliGT @ Jul 9, 2005 - 3:29 PM) u guys got bulbs? i didn't. i got the 2 prong connector that the bulb plugs into. [right][snapback]310474[/snapback][/right] I will verify when I get home. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jul 9, 2005 - 9:03 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Mine came with stock bulbs.
I saw someone reccomended Nokyo Artic Stage II's, which I got for like $17/pair, and have been impressed. RHD->LHD wasn't hard, I did it Thursday night on mine. Definetally do it if you are going HID or a bright bulb. Stock Hi's, 9006. Make sure you use these links: http://www.6gc.net/forums/index.php?showtopic=19182&st=40 http://www.6gc.net/index.php?action=howto&itu=57 http://www.6gc.net/index.php?action=howto&itu=142 -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jul 10, 2005 - 12:31 AM
J you can use your stock bulbs with the high beams. As many of you have already stated the low beams need an H1 and you need a special pronged connector which you can find at a autoparts store I believe.
HID is high intensity discharge if you havent already been told. Its not cheap and you need a ballast to ignite the bulbs. Its quite stunning but you cant do high/low w/o having 2 kits for the celica because there are 2 bulbs, not that you'd need HIDs in high beams anyways. I can show you pics of my setup if your interested in HID. -------------------- |
Jul 10, 2005 - 3:59 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
http://www.danielsternlighting.com/
Read everything on this site if you want to know how to improve your lighting -- and what not to do. |
Jul 10, 2005 - 4:15 AM
Has anyone fitted a HID kit into their projector low beams? I'm curious as to how that works, because I know that adding HID kits to a lot of cars with projectors and halogen bulbs from the factory does not work well, because the projector unit itself was designed for a halogen bulb.
Jul 10, 2005 - 4:55 AM
Coomer, Fietsbel has them. Already had some pics on the forum as well. Just use the search button
http://www.6gc.net/forums/index.php?showtopic=24418&hl= In the middle. -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 10, 2005 - 12:37 PM
QUOTE(Coomer @ Jul 10, 2005 - 5:15 AM) Has anyone fitted a HID kit into their projector low beams? I'm curious as to how that works, because I know that adding HID kits to a lot of cars with projectors and halogen bulbs from the factory does not work well, because the projector unit itself was designed for a halogen bulb. [right][snapback]310684[/snapback][/right] Ouch Coomer, very ouch. ![]() Almost 2 yrs I've had these. -------------------- |
Jul 10, 2005 - 12:47 PM
great info guys. It has helped a bunch. Thanks again.
Jul 10, 2005 - 1:14 PM
cant we just find the part number for the lhd version of these projectors?
Jul 10, 2005 - 3:26 PM
QUOTE(lagos @ Jul 10, 2005 - 7:14 PM) cant we just find the part number for the lhd version of these projectors? [right][snapback]310784[/snapback][/right] There arent any cause they were only fitted on Japanese Celicas. This post has been edited by Kadett: Jul 11, 2005 - 6:16 AM -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 11, 2005 - 7:48 PM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) |
Also, I'm note sure if anyone mentioned this- you can use the side-marker lights in the "accent" bulb on the low beams. You have to shave off a little bit of plastic to get them to fit in, but its pretty easy. Thats only if you want though...
Anyways. Best of luck. And when you get them hooked up, you will see the severe problem of the RHD lights. As soon as I get a free weekend, I'm trying Kadett's mod (thanks for writing it man!) -------------------- ![]() psalm 69 |
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:56 AM |
