Jul 12, 2005 - 12:33 PM
Enthusiast ![]() Joined Mar 1, '04 From Louisville, KY Currently Offline Reputation: 0 (0%) |
![]() Doesn't quite get there ![]() ![]() And then there's that gap where the lip sticks out a bit at the top. Any ideas on what I should do? I was thinking of cutting the wheel well sides a bit and maybe screw in from the bottom. someone suggested to heat gun the lip and then stretch it. But I dont know... |
Jul 12, 2005 - 1:02 PM
I would try to stretch it first, or if ur good w/ fg u could cut a spot and fill in as needed.
Jul 12, 2005 - 1:44 PM
Enthusiast ![]() Joined May 2, '04 From HTX Currently Offline Reputation: 4 (100%) |
i had the same problem. I just put it on and sanded down the corner that sticks out and re-fiberglassed it to wrap around more smoothly.
-------------------- I am ever so thankful for the 'Ignore User' capability on this forum.
Jul 12, 2005 - 2:07 PM
Enthusiast ![]() Joined Jul 5, '05 From New York ~ San Francisco Currently Offline Reputation: 0 (0%) |
Wow this like a totally missed fitted, You should call the company you got it from and asked them to send you a brand new one.
This post has been edited by Project95St202: Jul 12, 2005 - 2:07 PM |
Jul 12, 2005 - 2:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
well u can't send it back, but mine also had the same problem. I just forced that bad boy on there.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Jul 12, 2005 - 2:17 PM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From New York Currently Offline Reputation: 0 (0%) |
QUOTE(Drocay @ Jul 12, 2005 - 3:15 PM) well u can't send it back, but mine also had the same problem. I just forced that bad boy on there. [right][snapback]311602[/snapback][/right] thats what i did with my sides. it cracked a little when i put it in there then i put some fiberglass resin in there and called it a day |
Jul 12, 2005 - 2:32 PM
QUOTE(FoREpLayAX @ Jul 12, 2005 - 2:44 PM) i had the same problem. I just put it on and sanded down the corner that sticks out and re-fiberglassed it to wrap around more smoothly. [right][snapback]311588[/snapback][/right] what grit sand paper did you use? QUOTE(gtcelica94 @ Jul 12, 2005 - 3:17 PM) QUOTE(Drocay @ Jul 12, 2005 - 3:15 PM) well u can't send it back, but mine also had the same problem. I just forced that bad boy on there. [right][snapback]311602[/snapback][/right] thats what i did with my sides. it cracked a little when i put it in there then i put some fiberglass resin in there and called it a day [right][snapback]311603[/snapback][/right] how long ago was this? Do you see any sign of the crack coming back? I read somewhere on the forum that you should drill holes at the end of the crack to keep it from getting bigger. |
Jul 12, 2005 - 3:01 PM
aite wat you do
is measure how much its off go to the back dead center add slice it down the middle get a thin piece of metal and attach it to the back of the lip so that its held the exact measurement apart and sturdy lay fiberglass over the gap..... sand it down a little and smooth with bondo sand it down and primer sand it down and paint |
Jul 12, 2005 - 4:04 PM
Ok the best way, get a nice heat gun and heat it up and bend it to fit.
Jul 12, 2005 - 7:44 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
mine was kinda like that, but it was slide-on-able I tried putting it on like that, witch did not work for me, so I slid it up from the bottum and gave it a good wiggle, it aventualy got there with no problems, I would recomed trying again before any cutting or sanding.
keep in mind that its gana look shorter when its held out from the car, I would get a tape measure and check to distance from the door to the edge (pushed firmly to the car) then measure the kits inside distance to see if it really is shorter. to me it looks close enough to fit. This post has been edited by creis: Jul 12, 2005 - 7:47 PM -------------------- ![]() |
Jul 13, 2005 - 4:26 AM
if u want perfect wut u need to do is exactly wut dan mentioned, i did the exact same thing with my sides and my custom rear.
| Lo-Fi Version | Time is now: June 13th, 2026 - 4:10 AM |
