Jul 12, 2005 - 6:57 PM
Enthusiast Joined Jul 12, '05 Currently Offline Reputation: 0 (0%) |
Hope, someone would be a ble to enlighten me on this problem... & how to remove it of cos. Thanks!! |
Jul 12, 2005 - 7:17 PM
I'm assuming your using a spark plug socket? Try to get a light in there and see if you stripped it.
Jul 12, 2005 - 10:40 PM
Enthusiast ![]() ![]() ![]() Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) |
There are sparkplug sockets with the rubber inside the socket that helps get it out real easy, have you tried using one of those??
Jul 13, 2005 - 1:38 PM
QUOTE(Supersprynt @ Jul 12, 2005 - 7:17 PM) I'm assuming your using a spark plug socket? Try to get a light in there and see if you stripped it. [right][snapback]311697[/snapback][/right] Hi thanks for the reply. I got a light in wat i saw was like a reall shallow worn out plus as if it has never been changed out b4... surrounding the plug seems like there is a rubbery outer rim on it. I wonder whether if the plug was there ever since the car was born??? |
Jul 13, 2005 - 1:39 PM
QUOTE(CelicaSTX02 @ Jul 12, 2005 - 10:40 PM) There are sparkplug sockets with the rubber inside the socket that helps get it out real easy, have you tried using one of those?? [right][snapback]311807[/snapback][/right] Not exactly hehe. |
Jul 13, 2005 - 3:22 PM
Go to the autoparts store or if you have a decent ratchet set it'll have it there and use a spark plug socket. That way the plug will stay in teh socket and let you pull it out.
Jul 14, 2005 - 12:30 AM
Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
after its unscrewed take out the wrench and put the plug wire into the hole until it locks down onto the plug, then pull the wire out and its on the wire
Jul 14, 2005 - 9:08 AM
Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
QUOTE(roswell81 @ Jul 13, 2005 - 1:38 PM) QUOTE(Supersprynt @ Jul 12, 2005 - 7:17 PM) I'm assuming your using a spark plug socket? Try to get a light in there and see if you stripped it. [right][snapback]311697[/snapback][/right] Hi thanks for the reply. I got a light in wat i saw was like a reall shallow worn out plus as if it has never been changed out b4... surrounding the plug seems like there is a rubbery outer rim on it. I wonder whether if the plug was there ever since the car was born??? [right][snapback]311992[/snapback][/right] the rubbery outer rim you are talking about is probably part of the spark plug wire! get some long needl nose pliers and get it out of there and then you should not have any problems with the plug. oh and the spark plug socket is a 5/8 -------------------- ![]() |
| Lo-Fi Version | Time is now: June 12th, 2026 - 10:36 AM |
