> FMIC how to???, need help
post Jul 12, 2005 - 7:13 PM
cyb593
Joined Feb 22, '04
From USA
i see that lagos has done this i would like his help or anyone elses in structions on how to do this. what size pipping is there a place where i can buy all the piping the way i need it right now instead of getting it bent?? intercooler?? what do i get that will i need one for both intakes?? http://www.6gc.net/photo.php?file=/images/...hotos/60_14.jpg the 2 pipes here sorry Lagos i stole ur picture just for reference i hope u dont mind. how easy is this to do estimated time? is it easier than a air intake?? thanks would be grateful for the help. and also estimate cost??
post Jul 12, 2005 - 7:34 PM
what motor do you plan to install this on ? are you doing a swap ?
post Jul 12, 2005 - 8:51 PM
cyb593
Joined Feb 22, '04
From USA
it is a 5th gen that already had a 3sgte swap done has the intercooler on the top. has bout 200 hp.
post Jul 12, 2005 - 10:10 PM
just get some 2.25 in aluminized steal or stainless steal piping.
youll need around 1 J bend. 8 90deg bends and 2 -3 45 degs. then some t-bolt clamps and couplers.
it takes a full day to do it because the piping isint easy to cut with a normal pipe cutter.
post Jul 14, 2005 - 3:38 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
QUOTE(lagos @ Jul 12, 2005 - 10:10 PM)
[right][snapback]311787[/snapback][/right]
does anyone have step by step pics of this being done? Id like to do it to my 94' ST w/3s-gte as well.
post Jul 15, 2005 - 8:47 AM
scothaniel
Joined May 1, '03
From Michigan
A chop saw with a nice cutting wheel is your friend!
First off - clock the turbo! I dont know why people here aren't doing it on thier swaps. You pull a pin, rotate the compressor housing down, route the edge where the pin will be and make a bracket to hold the wastegate. Then the turbo is pointing downward and you dont have a big funky 180 degree turn going over the exhaust manifold. This keeps the air cooler, you save like 10 Feet of piping ( every 90 degree bend it the equiv of like 3 feet of straight pipe) and you shorten the overall path of to the throttle body - making the turbo even more responsive.
Its definately worth the time.
For the rest of the pipes - just order 2 or 3 U bends from JC Whitney or Summit - make sure its aluminized steel (or stainless - depending on what you can weld). Then you need a couple of silicone hump hoses and couplings. Get a buddy who can weld and go to town!
This post has been edited by scothaniel: Jul 15, 2005 - 8:48 AM
Scott
West Michigan
post Jul 18, 2005 - 12:49 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
you can go to a muffler shop & get it donn....
post Jul 18, 2005 - 1:48 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(scothaniel @ Jul 15, 2005 - 1:47 PM)
Word.
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 21, 2005 - 3:49 AM
ice23q
Joined Jan 16, '04
From sydney australia
id like to know how the pipework comes from the cooler..... what route does it take..... pics would be good.....
312whp with more to come....
Lo-Fi Version Time is now: August 27th, 2026 - 6:31 PM
