> problems with a 3sgte, having issues
post Jul 13, 2005 - 9:01 AM
cyb593
Joined Feb 22, '04
From USA
my g/f car is having issues. has a 3sgte in it and it will drive in reverse but when she puts it in first it wont go i mean it will a little but it like put puts and she cant even really make it up the hill anyone else know what the problem is please help thanks.
This post has been edited by cyb593: Jul 13, 2005 - 10:44 AM
post Jul 13, 2005 - 9:56 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
your clutch or tranny is going
have some ASE tech check it out ???
it mite be some thing minor, get it check
post Jul 13, 2005 - 12:29 PM
cyb593
Joined Feb 22, '04
From USA
she says it will go but it feels like it is drained of power. you still say it is the tranny or clutch?? just curious i dont know what it is
post Jul 13, 2005 - 3:32 PM
cyb593
Joined Feb 22, '04
From USA
bump need more info asap thanks
post Jul 13, 2005 - 4:09 PM
you are not really giving use enought specific info to go on
post Jul 13, 2005 - 4:23 PM
cyb593
Joined Feb 22, '04
From USA
well she puts the car in reverse and it goes fine like normal but when she puts it in first its like it lost almost all power and it goes put put put like not getting enough fuel. i told her i think it is a fuel injector issue or fuel pump and she asked someone related to her that is a mechanic and he said the same but he said it could be a belt issue also. it just started this morning. it feels like the car is drained of its power in the drive. i figured that was to quick for a clutch problem or transmission it would take longer for it to get there. is that enough information let me know if u need anymore to help me with this issue. thanks lagos
post Jul 13, 2005 - 6:01 PM
umm a air leak in the vac hoses, inake piping or intercooler piping, a loose afm could do that.
how does the car idle?
post Jul 13, 2005 - 11:56 PM
cyb593
Joined Feb 22, '04
From USA
not sure. what is a amf??
post Jul 14, 2005 - 3:10 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
afm is air flow metering, tells the ecu how much oxygen is in the air, thus how much fuel to use etc.
AIM : FAQdaWorld
post Jul 14, 2005 - 3:25 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
i doubt its a vacum leak cause it would have a rough idle, and same issues forwards or reverse. Have the tranny checked out sounds like you bent or broke 1st gear, can the car start off in 2nd gear fine with the normal bit of lag?
post Jul 14, 2005 - 10:23 AM
cyb593
Joined Feb 22, '04
From USA
i can try to start it in 2nd gear. i dont know how u can brake first gear. i mean she was new at driving a manual but she didnt do anything to bad besides bump around. that doesnt sound like something that happens. and this would happen over night i will try to drive it in second gear tonight.
Lo-Fi Version Time is now: August 23rd, 2026 - 11:37 PM
