> How to know if the clutch need to be changed?, I just know how to drive a stick :)
post Jul 13, 2005 - 7:06 PM
Love6GC
Joined Jun 20, '05
94 st 105K
Just got a quote: 710$ including parts 200, labor 500 sth.
I think I paid to much for the car $3,000 if the clutch need to be changed soon.
What will happen if the clutch goes really bad?
Thanks
post Jul 13, 2005 - 8:14 PM
dabbill
Joined Aug 26, '04
From Vancouver, WA
buy a clutch kit for 100$ and change it your self.
post Jul 13, 2005 - 9:04 PM
Well thats an AWFUL lot to do a clutch change. I think you should definately get at least a second opinion if not a third.
Also, thats LOW mileage for an 94 so 3,000 is definately not too much.
And the easiest way to tell if your clutch is close to on its way out is where in the pedal travel the clutch is engaging. Which means, when your lifting your foot off the clutch, how far can the clutch pedal come up before the car starts moving? If it is almost all the way up and its not moving yet (engaging) then your clutch is pretty worn. If the pedal is close to the floor and you feel the clutch engaging, its newer.
post Jul 13, 2005 - 10:21 PM
Love6GC
Joined Jun 20, '05
QUOTE(Supersprynt @ Jul 13, 2005 - 9:04 PM)
[right][snapback]312127[/snapback][/right]
Thank you very much.
post Jul 14, 2005 - 5:42 PM
tomazws
Joined Oct 30, '04
From So Cal
hmm... or, go 2k RPM on second. Then, floor the gas. If your RPM shoots up but the car's not responding (or not as responsive), then your clutch is old and most likely needs replacement. If your RPM needle goes up slowly along with our car's slow acceleration, then don't worry bout it =)
post Jul 15, 2005 - 7:17 AM
Illyont
Joined Apr 8, '05
From Norway
QUOTE(tomazws @ Jul 14, 2005 - 5:42 PM)
[right][snapback]312455[/snapback][/right]
post Jul 15, 2005 - 11:54 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
set the parking brake
put it in 1st, and try to get moving
if the car stalls, or starts moving, the clutch is OK
if it continues to rev while hardly moving, then its time to replace it.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jul 15, 2005 - 4:49 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
The labour you've been quoted is about the same as I'll be paying - but on the GT4 the entire engine and gearbox has to be pulled out!
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Jul 15, 2005 - 5:04 PM
mr_dude
Joined Feb 16, '04
From San Diego
QUOTE(GT4WRC @ Jul 15, 2005 - 1:49 PM)
Gary
[right][snapback]312837[/snapback][/right]
Yup, I went to the dealership and they wanted 1200. About 900 for labor since the gearbox has to be pulled out. And what's worse, he said our model clutches only last 5-7 years.
The ghetto repair shop wanted 1000.
It's sad because otherwise the car is very well built.
Yeah if you let the clutch all the way out and have no power at the wheels, the clutch is almost done.
post Jul 15, 2005 - 10:38 PM
Love6GC
Joined Jun 20, '05
Thanks for the tip. I tried it, it seems my baby still runs strongly if I floor the gas at 2nd. RPM up fast but steady, speed to 35+mph
Tthe clutch point a little bit high from the floor.
post Jul 15, 2005 - 10:44 PM
Love6GC
Joined Jun 20, '05
QUOTE(97sccelica @ Jul 15, 2005 - 11:54 AM)
[right][snapback]312729[/snapback][/right]
I happened to try this on R gear. smile.gif It can overcome the parking break.
post Jul 15, 2005 - 10:49 PM
Love6GC
Joined Jun 20, '05
QUOTE(mr_dude @ Jul 15, 2005 - 5:04 PM)
[right][snapback]312841[/snapback][/right]
I can still just use the clutch with no gas start the car on a flat road.
So the clutch is still ok, right?
post Jul 16, 2005 - 1:44 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
can anyone who has changed their clutch on an st put a how-to up on how to do it
post Jul 16, 2005 - 5:51 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(MonsterBOX @ Jul 16, 2005 - 6:44 PM)
[right][snapback]313087[/snapback][/right]
Do a search... I wrote step by step instructions one time through PM's to another member here... and it was posted once. Search for it.
post Jul 17, 2005 - 1:14 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
been lookin for a while i cant find it
post Jul 28, 2005 - 4:41 PM
gt2nv
Joined Mar 11, '03
From Springfield, Ohio
what about a slave cyclinder, how do you know when it needs replaced. i think that mine might be bad, clutch is fine in 1st and 2nd, but started to slip in 3rd - 5th. anyone got any advise?
Lo-Fi Version Time is now: September 1st, 2026 - 2:01 AM
