> PROJECTOR LIGHTS, Only fit 96+?
post Jul 16, 2005 - 3:57 AM
tranxendz
Joined May 2, '03
From San Diego
I was reading the part numbers that Coomer posted up...I noticed the projector headlights are for 96+ is that true?? I'm so dissapointed because I'ev noticed a lot of things are for 96+
post Jul 16, 2005 - 4:13 AM
hisashi94gtst204
Joined Jun 14, '05
From Honolulu
I have a 94 gt hatch and i got the projectors on.
post Jul 16, 2005 - 4:19 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Only the internal compenents (the projector) is different. The housing has the same mounting points.
post Jul 16, 2005 - 9:16 AM
ghostdog
From ny to philly
pretty much all bodyparts are interchangable between the years. all you have to do is slap on the 96+ bumper, thats what I did wink.gif
QUOTE(tranxendz @ Jul 16, 2005 - 4:57 AM)
[right][snapback]313008[/snapback][/right]
post Jul 16, 2005 - 9:53 AM
Currently Online
QUOTE(ghostdog @ Jul 16, 2005 - 7:16 AM)
[right][snapback]313032[/snapback][/right]
Though you don't need to change bumpers to install the projector headlights. I know you know this Pete but the way it's worded it makes it a bit unclear. wink.gif
post Jul 16, 2005 - 11:02 AM
ILuvMyCelica95
Joined Dec 16, '02
All that means is that the Projectors were installed on GT-4 from 96-99. The 94-95 did not have them as an option.
I have projectors and my car is a 95. The only thing that needs to be modified is the wire connecting the low beams, ( and i belive that the wire is needed if you are installing it on any celi that has stock lights) you can get the harness at Autozone or one of those similar auto parts stores. The instalation is very easy and they look amazing biggrin.gif
post Jul 16, 2005 - 1:04 PM
ghostdog
From ny to philly
QUOTE(Coomer @ Jul 16, 2005 - 10:53 AM)
[right][snapback]313037[/snapback][/right]
ha I thought it was a bit unclear myself. thanks for the clarification
post Jul 16, 2005 - 1:59 PM
Kadett
Joined Mar 17, '05
Keep in mind that they are for Right Hand Drive cars only. And if you install them on a LHD car u will either have to adjust the beam downwards or modify the projector itself.
Lo-Fi Version Time is now: June 11th, 2026 - 10:14 AM
