Jul 18, 2005 - 4:24 AM
Enthusiast ![]() ![]() Joined Dec 21, '04 From Netherlands Currently Offline Reputation: 0 (0%) |
I have a ST at the moment, is it possible to transer the brakeclaw and disc from a GT on a ST? Bigger brakes are always better.
Or what do i have to modify to make it work This post has been edited by Fietsbel: Jul 18, 2005 - 4:25 AM -------------------- |
Jul 18, 2005 - 6:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
I think that the only diff in brakes is that the gt has rear disks and the st has rear drums. so unless your talking about a drum to disk swap then I dont think swaping to gt parts will make a diff.
Jul 18, 2005 - 7:01 AM
I thought that the GT discs are bigger. I have front and rear discs on my ST.
This post has been edited by Fietsbel: Jul 18, 2005 - 7:01 AM -------------------- |
Jul 18, 2005 - 10:05 AM
GT front discs are larger... 275mm verses 254.7mm
You don't have to modify anything. Just swap over the rotors and calipers. -------------------- "It's ok to be naked girl... I'm an artist!"
Jul 18, 2005 - 12:58 PM
Great, so GT4 calipers will fit as well?
Jul 18, 2005 - 1:11 PM
no gt4 calipers don't work since they are superstrut suspension and the GT/ST is mcpherson from what i understand but get this info double checked
Jul 18, 2005 - 8:59 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
To swap the calipers -- GT or GT4 -- you'd need the brackets they sit on and with the GT4, you'd also need the backing plate that holds the bracket.
Jul 19, 2005 - 12:43 AM
QUOTE(Galcobar @ Jul 19, 2005 - 1:59 AM) To swap the calipers -- GT or GT4 -- you'd need the brackets they sit on and with the GT4, you'd also need the backing plate that holds the bracket. [right][snapback]314017[/snapback][/right] Don't need the backing plate. On the front, those are more or less a dust cover. You don't even really need to run them if you don't want to. As for the GT4 calipers, the caliper bracket spacing is the same between the two calipers (ST/GT vs GT4), but the actual knuckles are totally different, the GT4 having super struts, extendes the knuckle out father to clear the rotors, while the GT/ST doesn't. Consider this, between the 03+Civic SI and the Acura RSX-S, the RSX has something like 12 inch diameter rotors while the Civic has 10.5 inches or so. They however share the same caliper, the difference between the two are the spindles and knuckles, which extend farther on the RSX-S than the Civic SI. -------------------- "It's ok to be naked girl... I'm an artist!"
Jul 23, 2005 - 1:29 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Kwanza will you marry me?
I mean seriously dude you know SO MUCH! You're always a great help it seems on these forums. -------------------- AIM : FAQdaWorld
Jul 24, 2005 - 9:22 PM
Front or rear wasn't specified, and rear discs were mentioned.
Jul 25, 2005 - 12:59 AM
QUOTE(Galcobar @ Jul 25, 2005 - 2:22 AM) Front or rear wasn't specified, and rear discs were mentioned. [right][snapback]316362[/snapback][/right] He has a Euro spec Celica... which measn he already has rear disc brakes. More than likely, refrence was between the front brakes of ST/GT. -------------------- "It's ok to be naked girl... I'm an artist!"
Jul 25, 2005 - 2:48 AM
Agreed -- though other participants with STs were from North America.
| Lo-Fi Version | Time is now: May 20th, 2026 - 8:59 AM |
