> car alarm, stopped working???
post Jul 20, 2005 - 11:04 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
all of a sudden my shock and prox sensors quit working i had spliced them 2gether cuz there was only one spot to hook it up. and today my remote got wet cuz i work at a water park and it stopped (my fault) and so i used the key to open getting redy to get in and reset the alarm and it didnt go off when i opened it. not good not good at all.
My car = 0-60 in ~9sec
It's slow, I know
Replies (1 - 6)
post Jul 21, 2005 - 12:53 AM
First thing would be to check the alarm fuse.
You diode-isolated those sensors, right?
post Jul 21, 2005 - 1:36 AM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
well if i knew what diode isolated was then the answer would probably be no but the fuse is fine and the remote unlock and lock work and the chirp works and the trunk release works but when the driver door opens when activated nothing happens
It's slow, I know
post Jul 21, 2005 - 3:22 AM
Did the alarm used to go off when you opened the door with the key with the alarm armed?
Does your dome light and door-open indicator come on when you open the door?
Oh, and diodes are kind of like one-way valves for electric current. This link explains them well.
post Jul 21, 2005 - 1:38 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
in answer to the door question yes the driver door did set the alarm off before and with the diodes i connect the power part of the sensors to them? im not sure which one is the power wire. i think i might have fried the sensors because i connected just the shock sensor to it and it didnt even say it had power to it. both the pass and driver door dont trigger now. and the door indicator and dome light comes on
This post has been edited by chicklover345: Jul 21, 2005 - 2:00 PM
It's slow, I know
post Jul 21, 2005 - 2:26 PM
Well, your alarm manual should tell you which color wire going to the sensor does what. Typically there are four wires - +12v, ground, an instant ground trigger, and a warn-away input. I believe that you want to diode-isolate both the instant trigger and the warn-away input. I can't remember for sure though...searching on the12volt.com will yield an answer I'm sure.
About the door trigger, find the door trigger wire on your alarm, and verify that it gives +12 volts when the doors are closed and gives ground when a door is opened.
post Jul 21, 2005 - 3:15 PM
chicklover345
Joined Jul 16, '03
From Boise, Idaho
ok ill try that thank you
It's slow, I know
Lo-Fi Version Time is now: August 11th, 2026 - 5:54 PM
